Agency Power Throttle Body and Plenum can cause an intermitent limp mode
Old Mar 22, 2012 | 09:25 AM
unvmy996's Avatar
so you actually did a proper boost leak test ? and re checked all the vacume line ?
Old Mar 22, 2012 | 11:00 AM
johnspeed's Avatar
HI,,I know this might sound bad........But....Why dont you just put the stock stuff back on since you said the car ran fine until this??..Has Vivid tryed to help with this? This seems like it has been a headache for you and it has not improved with all your trouble shooting??....Maybe it just was not met to be.....LOL....Good Luck
Old Mar 23, 2012 | 05:55 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i have the same problem with my stock carrera, it does it at random speeds and in random gears though, we've tried everything we can think of, replaced throttle, checked all the wiring, it went away for a while but just happened again yesterday, mechanic says replacving the dme is the only thing left to do so we will try that next
Old Mar 23, 2012 | 08:47 AM
911turbofreak's Avatar
911turbofreak is infamous around these parts
John this is excactly what I do, put back the stock throttle, so I let you know hows going when I finish.
Old Apr 16, 2012 | 09:31 PM
Well, I'm finish, I swap the AP trottle body for the stock trottle body and the car is running perfect!!! no more intermittent limp mode
Old Apr 17, 2012 | 12:54 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
When you installed the new TB , did you retune the car ?
Are you sure you installed it well ?
Did vivid try to help you out to solvr this issue ?
Yousef
drinaldis
Sep 28, 2015 01:37 PM
turbotuner20v
Sep 11, 2015 12:02 PM
nreddy
BMW //M
Aug 26, 2015 11:42 AM
Ferrari
Aug 24, 2015 04:35 PM
magoochi
Aug 23, 2015 05:54 PM
