Aftermarket satnav and car horn blip
Old Mar 16, 2012 | 08:40 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
I am installing aftermarket satnav this weekend.
Apparently there is an issue with OEM Becker radio. As the Becker is removed the horn will blip when you remote lock the car unless you bypass this feature. Just like if you leave glow compartment or central locker opened.
Can anyone tell me how I prevent this? What wire is it I need to bridge, electrical installation wise?
Thanks.
Old Mar 16, 2012 | 09:56 AM
pwdrhound's Avatar
Thanks.
Very simple. If you are using an aftermarket stereo then you need to disconnect the radio alarm sensor wire (black with blue stripe I believe) that is attached to the sensor bracket on the radio cage. Just disconnect the female spade connector from the bracket (located on the left side of the radio cage) and wrap with tape.
Old Mar 17, 2012 | 01:51 AM
Terminator's Avatar
Tanx mate.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
Fabspeed Motorsport
Aug 18, 2015 03:24 PM
Fabspeed Motorsport
NY Tri State
Aug 18, 2015 03:22 PM
HolmaN
Aug 18, 2015 01:35 PM
