procedure to replace clutch master cylidner?
Hey guys, as the title states, I need to replace my clutch master. The only instructions I have found are in connection with a full gt2 clutch slave conversion, which I have already done.
My question is whether I should drain all the fluid (now brake fluid) out of the system before I go to remove the clutch master cylinder attached to the pedal? I have a motive power bleeder I'll be using. I'm assuming I should drain the fluid completely using the power bleeder, remove the master cylinder, replace, and then flush the fluid completely through the system until there are no more bubbles to ensure no air is in the system. Does that sound right? Any tricks or tips? Thanks!
It's probably the best method as that way your guaranteeing no air in the system. Use a hose attached to the bleeder screw on the slave to help collect the fluid from going everywhere.
Good luck at least it's fairly easy, just a pain.
