RS Mount Catastrophe!!
Old Mar 29, 2012 | 12:13 PM
Yazz911TT's Avatar
Yazz911TT is infamous around these parts
The Result of 2 launches at the drag strip!!! Any1 else had this problem?? Put the stock mounts back in, no problems after 10+++ Launches!! RS Mounts suck....my advice...STAY AWAY!!
Old Mar 29, 2012 | 12:41 PM
wow that sucks. assuming you needed a tow?
#TeamAIM
Old Mar 29, 2012 | 06:28 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
If you're launching that hard get the Wevo semi solids and a tranny mount with derlin inserts.
Old Mar 29, 2012 | 06:55 PM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
This is a result of 2 launches, come one man were these used before and how old are they? This doesn't add up.
Old Mar 29, 2012 | 08:35 PM
RennFab's Avatar
RennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of light
Agreed. I've seen these mounts take abuse.
Old Mar 30, 2012 | 12:50 AM
John@SpeedTech's Avatar
I have over 40 drag strip with glue launches on mine with no issues.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Mar 30, 2012 | 01:27 AM
SamboTT@ByDesign's Avatar
There is a sequence of nuts, spacers and such that has to be installed correctly. Maybe that was the issue. I also have given those a beatin' on my 993 and 996. Wierd S@#% happens all the time though.
Old Mar 31, 2012 | 12:40 PM
Yazz911TT's Avatar
Holy ****!! I had mine mounted with the carrier bracket things that sit under the standard ones!!! Maybe thats where I went wrong!!
Old Mar 31, 2012 | 12:41 PM
Yazz911TT's Avatar
They are BRAND SPANKING NEW FROM PORSCHE!! They were on the car a month but only road driving.....this was the first time I went to the drag strip!!
Old Mar 31, 2012 | 01:47 PM
They are tricky. Those parts also have top and bottom. Cool mounts though.
Old Mar 31, 2012 | 02:22 PM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
So... the failure was due to installation error, then?
Old Apr 1, 2012 | 02:56 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Sambo's pics are from a 993 turbo. It's engine carrier and chassis are different from 996's. IMO independent of the type of mounts used on 996 turbo/GT3 OEM spacers are required between the mounts and chassis. Otherwise the engine will sit too low.
Old Apr 1, 2012 | 11:39 AM
Thanks Pete. Couldn't find pics in a 996. They do sit on the spacer in a 996+. If the washers are installed properly they work fine. 993 996 and 997 mounts are the same.
Look here for ref.
http://www.suncoastparts.com/product...996performance
PV=nRT.
Sep 9, 2022 06:06 PM
jaehoppa
Oct 22, 2015 09:17 PM
