CEL code help p1109
Old Apr 2, 2012 | 08:59 AM
powderjay's Avatar
powderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to behold
CEL code help p1109
Did the search to no avail. Recently did a bunch of work on the car; cayenne tb, ap plenum, speed tech y-pipe, bmc filter. Ya I know lots of different manufactures, anywhoo, is my maf toast or is there some kind of boost leak?? Can't find that code. Any help would be great.
Old Apr 2, 2012 | 09:59 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Search on here, lots of different causes. I had this when my new TB did not mate to the plenum properly. I made a new gasket that was thick, and ditched the o-ring.
Tom
Old Apr 2, 2012 | 10:01 AM
tvurt's Avatar
Oh and make sure you test for boost leaks at every stage of reassembly, from the all the way back to the turbos, then from the intake. LOTS of stuff to go wrong here, but all easy fixes!
Tom
Old Apr 2, 2012 | 10:37 AM
powderjay's Avatar
Ya had a custom braket made to mount the plenum to tb. cost me 200 bucks looked good and made the parts fit nicely. Have not checked for leaks yet.
Old Apr 4, 2012 | 07:42 PM
powderjay's Avatar
Code says. Secondary port throttle system. Any body have a clue why? Or how to fix??
Old Apr 4, 2012 | 08:03 PM
Macster's Avatar
MAF is suspect or another possibility is the mods have resulted in turbulent air flow past/through the MAF and it is supplying invalid readings.
The error code points to 'input variables, charge measurement -- above limit'.
With all the mods you have to walk through then and make sure everything is hooked up correctly.
Beyond that I have nothing more at this time to offer.
Sincerely,
Macster.
Old Apr 4, 2012 | 10:44 PM
MBailey's Avatar
Usually means small boost leak or leak in the intake piping, in my experience...
Old Apr 5, 2012 | 02:21 PM
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
But how is the LWFW???
tvurt's Avatar
LEAK LEAK LEAK!
There you go.
Old Apr 5, 2012 | 03:22 PM
powderjay's Avatar
Can't tell, don't want to blow up the engine. Leak test soon
Old Apr 5, 2012 | 05:13 PM
AlexN's Avatar
AlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud of
I'm getting that one every once in a while.
I was told that my Evo intake is probably causing it.
It will usually clear itself after a few hours
Old Apr 5, 2012 | 06:27 PM
SamboTT@ByDesign's Avatar
Many people have traced this down to a leaking valve seat. I had the same thing as Alex and chased my tail for a while. Luckily it was my car with the gremlin not a customer.
Anyhow it's almost always a leak somewhere at nothing more. Could be under the plenum too. You will find it. good luck!
BLKMGK
May 31, 2016 04:32 AM
intouch1
Sep 20, 2015 06:14 AM
Yogi911
Sep 9, 2015 08:20 PM
