Stiff Clutch Pedal
Old May 26, 2005 | 10:59 PM
PMD's Avatar
PMD
PMD is infamous around these parts
Angry Stiff Clutch Pedal
Yesterday just after a cold start, the clutch pedal got very gittery and stiff. It loosened up a bit after driving a while, but it is still very stiff compared to how it was. It is even more stiff when the car is off.
The clutch was replaced about 6 months ago with OEM parts. They also changed the slave and accumulator at the same time.
Any thoughts??? Thanks
Old May 27, 2005 | 09:43 AM
45otto's Avatar
Kills Bugs Fast
45otto is infamous around these parts
Check your hydraulic fluid, do you hear a whining from the motor? I think the same fluid system drives both the clutch and the steering, does the steering seam normal?
Old May 27, 2005 | 09:47 AM
Under PSI's Avatar
Under PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud of
The same thing happened to me about a month ago. (my clutch has never been replaced). The slave cylinder had failed.
Old May 27, 2005 | 10:21 AM
Turbo Racer's Avatar
Turbo Racer is infamous around these parts
yeah, had this a long time ago and was easily fixed with some hydrolic feel. funny the dealer asked if i had a gt2 clutch, seems that this is what one feels like.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
sparks
Sep 8, 2015 03:03 PM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
