Had to get my car towed.. help!
Subscribe
Apr 6, 2012 | 01:29 PM
Hey guys.. last night I had to call a tow truck to take my TTS (auto) to the dealer.
When I turned on the car and started driving out of the parking lot, I noticed engine hesitation and reduced power (even going 15 km/h in the parking lot). It would almost stall if I give it a little gas, the RPM would dip really low (200-300) then pick up. Then the ABS and PCM-off warning lights came on. It actually stalled a few times, but it would turn back on every time no problem (weird..). I barely made it out of the parking lot then parked again and waited for the tow truck.
Any clue what may have happened?
Reply
Apr 6, 2012 | 01:37 PM
Always disconnect MAF, then test drive before calling a tow. Not sure if this would have helped but something to consider.
Reply
Apr 6, 2012 | 06:55 PM
Thats what mine did before it died completely. Was a bad fuel pump. hope that helps
Reply
Apr 6, 2012 | 08:26 PM
agree on possible fuel pump. when mine went, any pressure on gas pedal led to stalling.
Reply
Apr 7, 2012 | 07:40 AM
Howany miles did you get on your pumps before replacing?
Reply
Apr 7, 2012 | 12:24 PM
ek remember to do your fuel filter.
Any news Sam?
Reply
Apr 7, 2012 | 12:40 PM
Yeah, there were fault codes from the MAF and torque converter. They're still checking it out.. .waiting for their call tomorrow.
The fuel pump failing came to my mind too... I once had this fail on my BMW X5 and it sort of felt similar, except with the Porsche I could idle it for a long time, so I guess fuel was still reaching the engine.
Will update as I get more info.
Reply
Apr 8, 2012 | 10:19 AM
Yep, the MAF was faulty... getting it replaced.
Reply
Apr 8, 2012 | 10:49 AM
Sam- not to be cruel, but let us know how much it ends up costing...
So members can appropriately weight the wisdom of this board!
A
Reply
Apr 8, 2012 | 11:39 AM
I was quoted about US$750 for the part and $90 labour. I live in Dubai so prices in other countries may differ.
Reply
Apr 8, 2012 | 03:03 PM
^ Eh, actually I thought they'd screw you on a couple of hours to diagnose. Not bad.
And I do know Dubai pricing. What kills me, is not so much the cost- but the astonishing incompetence and shameless profiteering.
A
Reply
Apr 11, 2012 | 03:51 PM
Just an update for the benefit of those who may have a similar problem. The dealer changed their mind about the MAF and found that I had a loose air hose leading to the turbo booster, so they tightened it back on and so far the car is OK with no codes.
Reply
Apr 23, 2012 | 12:06 PM
ANOTHER update... got the ABS/PSM lights on again after a week with the same hesitation/stalling problem. This time got MAF replaced. Let's see how that goes.
Reply
Apr 23, 2012 | 10:13 PM
FYI there are a ton of DIY posts on how to change the MAF which is literally 2 screws and takes maybe 30 seconds.... and you can get it for around $250-300 at various places... don't waste your having the dealer do this.
Reply
Subscribe
