Air in brake line
Old May 7, 2012 | 07:39 PM
leeshdw's Avatar
leeshdw is infamous around these parts
Air in brake line
I was upgrading all of my brakes to the yellow ceramic ones. Everything was ok until the last one. I was bleeding the fluids and kept an eye on the fluid level. When I was pumping the brake pedal, it felt different. So i stopped and look at the fluid level. There was still fluid in there. Well I took a flashlight to it and noticed that the front half had fluids and the back half of the reservoir was empty.
So my question is, do i have to start all over again or just do the front ones since they are closes.
Thanks.
Old May 7, 2012 | 10:04 PM
pwdrhound's Avatar
Thanks.
The front half of the brake fluid reservoir is for the back brakes, the rear portion is for the front. They are separate for redundancy I believe so that if you get a leak in a brake line somewhere you don't loose all the fluid. I don't believe you need to rebleed the whole system but not 100%.
Old May 8, 2012 | 04:53 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
YES, You do need to bleed the whole system if you want to be sure that you have no air in the lines.
Air in the lines is bad.
Old May 8, 2012 | 06:12 AM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Agreed. Best to do them again.
Get a Motiv Powerbleeder and you won't have to pump any pedals
They're fantastic. (~70$)
Old May 8, 2012 | 11:01 AM
leeshdw's Avatar
Ordered the Motive Powerbleeder last night and another bottle of Motul, should be here today. I have the speedbleeder but will go back to the regular ones. Will do all four corners again.
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
