Clunking sound from front brakes..
Old May 8, 2012 | 09:58 AM
DNugget991GT3's Avatar
Guys,
I cant figure this out.
I replaced my front rotors and pads.. Stoptech 355mm Slotted rotors, and Hawk street pads.
anyway.. the brakes work great. i broke them in properly (2 rounds of ten 80-10mph runs)
heres the problem. when i am driving around, and the brakes arent applied, they make a clicking sound. it almost sounds as if the brake pad is shifting at a particular spot of the rotor.
we took the pads out, we put grease, we swapped the pads around.
the second i apply the brakes, the clicking sound dissapears.
what are your thoughts ?
my rotors are "floating". should i have the bolts tightened and essentially have a non floating rotor ?
Old May 8, 2012 | 04:59 PM
Tim941NYC's Avatar
Steve, Floating rotors will make that noise. If you do not like it then you should have used a street friendly rotor that has spring clips that put just enuff pressure to stop the noise but allow the rotor to float.
Old May 8, 2012 | 07:57 PM
Tim. This is the street "st-60" kit. I've had them on the car since day 1. They've never made this noise before. Do you think the culprit is the rotor or the pad ?
Old May 9, 2012 | 12:12 PM
Tim941NYC's Avatar
The spring clips on the bolts that hold the rotor to the hat.
Old May 9, 2012 | 12:17 PM
Tim941NYC's Avatar
Steve the ST-60 is the caliper not the rotor.
Enemy
Nov 10, 2015 08:01 AM
Zero911
Aug 24, 2015 06:51 PM
richard2966
Bentley
Aug 22, 2015 03:33 PM
