Has Anyone Seen Michelin PS2 315/25/19's?
Old Jun 22, 2012 | 02:12 PM
  #31
JayAndreTT's Avatar
JayAndreTT is just really niceJayAndreTT is just really niceJayAndreTT is just really niceJayAndreTT is just really niceJayAndreTT is just really nice
Originally Posted by prodigymb
Will he pay for your front diff when it fails or will you just go RWD ?
Definitely not, and not willing to do that either
Old Jun 22, 2012 | 02:25 PM
  #32
damon@tirerack's Avatar
Moderator
Originally Posted by pwdrhound
Please don't take this the wrong way as I mean no disrespect but obviously you have no idea how our very basic purely mechanical viscous clutch AWD system works. Champion specializes in 997s but they should know better. The sizes they quoted you are for a 997tt which uses a totally different electronic AWD system. The 996tt relies on a specific tire size ratio front to rear to function properly. Do as you wish however.....It is your car...
I agree. The 997 will not give you the "rope" the 996 does. The AWD system is much more sensitive. On a 996 you need to stay within 4% of the same OD front to rear. On the 997, it should be more like 2%, and the rears have to be .5" taller than the front to be correct.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jun 22, 2012 | 03:44 PM
  #33
pwdrhound's Avatar
Damon, the % difference is one thing but what people keep overlooking is that, for example, a 2% larger rear than front is totally different than a 2% larger front than rear. On the 996tt, YOU MUST HAVE AN EVER SO SLIGHTLY LARGER FRONT THAN REAR DIAMETER for the viscous coupler to transfer torgue to the front. Either that or different final drive ratios which we do not have as both are 3.44.
Old Jun 22, 2012 | 03:48 PM
  #34
pwdrhound's Avatar
[quote=JayAndreTT;3575039]
They are pretty stubborn in that they claim the fitment is fine. Guess I should return them and just get a new set despite what they say?
Ask them to put in writing that this tire combo will work properly on the 996tt and not damage anything. They won't...
Ask them to explain to you how the mechanical AWD system with viscous coupler works on the 996tt. Deer in headlights look, guaranteed......
Old Jun 22, 2012 | 03:54 PM
  #35
Zookie's Avatar
why dont we get Champion in here to Explain? ill PM them this Thread.
  #36
JayAndreTT's Avatar
Yeah I wouldn't count on it either. So basically, the stock fronts are 225/40/18 and rears are 295/30/18. Would you recommend for a 19 inch wheels I just go 225/40/19 and 295/30/19? Is there still enough space in the well to drop the car a tad?
Old Jun 22, 2012 | 04:02 PM
  #37
pwdrhound's Avatar
Yes, the above 225/40/19 and 295/30/19 will work and should not rub unless you have some funky offsets. The stock fronts are 25.1" and the stock rears are 25.0". As you can see, Porsche is using SLIGHTLY larger fronts. Pick a combo that will satisfy this simple requirement, either same size or tiny bit larger front. 19" wheels are a bit of a curse now since the 315/25/19 is no longer made. 235/35/19 (25.5") and 315/25/19 (25.2") was the proper size for AWD. Look at post #24, third paragraph, and you will see several combinations that will work properly with 19s. Your best bet is to stay with 18" wheels which will give you a number of options and better handling to boot. 19s are bling for the street, 18s are for performance....
Old Jun 22, 2012 | 04:15 PM
  #38
JayAndreTT's Avatar
With 18 inch wheels I can just stay at stock tire fitment right? (front at 225/40/18 and rear 295/30/18) I would want to reuse the Pilot Sports I have now on the stock wheels.
Old Jun 22, 2012 | 04:37 PM
  #39
pwdrhound's Avatar
Yes, and you can also run 235/40/18 and 315/30/18 which works great. That's my track set up.
Old Jun 22, 2012 | 05:26 PM
  #40
randomquickness's Avatar
randomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to behold
As much as people love to say the 997 sizes are fine, to include some dealerships, take heed to what these guys are saying. By the book, you're looking at close to a $10k repair with parts and labor through a dealership when that diff goes "POOF" > wobble wobble shake shake.
ask me how I know
Old Jun 22, 2012 | 05:32 PM
  #41
JayAndreTT's Avatar
ask me how I know
Well I actually just lucked out. My friend will be buying my wheels since the fitment is perfect for 997tt! Offset is 44 for rear and 53 for front, is that okay for a 997tt?
Old Jun 22, 2012 | 08:08 PM
  #42
pwdrhound's Avatar
that is good offset for 997tt
Old Jun 22, 2012 | 08:25 PM
  #43
enoyskt's Avatar
enoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to behold
Are we safe to say 225/40/19 and 295/30/19 is an ideal setup aside from using 315 25 19 rears?
Any fitment issues in the wheel wells or just extremely close?
Old Jun 22, 2012 | 11:18 PM
  #44
Zookie's Avatar
295 might be a Strech Fit on a 11.5 or 12" Wheel.
Old Jun 24, 2012 | 12:52 AM
  #45
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
This cannot be true. Read the manual. Porsche recommends a winter tire size that has a larger rear diameter than the front.
