Forge DV - Correct spring?
Old Jun 1, 2012 | 02:03 AM
vshugo996's Avatar
vshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to behold
Hi,
My Forge DV cames with 4 springs (green, yellow, blue and red).
My 996TT is running 1.2/1.3 BAR and the waste gates are oppening at 13 PSI.
What is the most suitable spring for my setup?
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Thanks,
VS 996TT
Old Jun 1, 2012 | 08:11 AM
I actually had a problem with this recently. I run 2 bar and I assumed I needed the Blue spring. I had some issues with DVs not being able to release enough air due to stiffness of the spring.
I would either use a Yellow which is what I use now or use the Green if you have issues with Yellow. Yellow was the preinstalled one in my Forge 008 DVs.
#TeamAIM
Old Jun 1, 2012 | 08:49 AM
vshugo996's Avatar
Hi,
Ok. So more stiff spring not means more turbo pressure.
Please, can you describe your problems with the blue spring.
Thanks,
VS
Old Jun 1, 2012 | 08:54 AM
Originally Posted by vshugo996
Hi,
Thanks,
VS
You DEFINETLY do not want to run the BLUE spring on your car. Trust me.
DVs are electronically controlled by a solenoid and it cant handle the BLUE spring.
#TeamAIM
Old Jun 1, 2012 | 09:10 AM
vshugo996's Avatar
Prodigymb,
I understand you and I will not go install the blue spring.
However, my car run only 1.2/ some times 1.3 BAR and I would like conclude if the green spring is better than the yellow.
I would like know your issues with the blue spring to compare with mines.
I can not get 1.3 BAR solid. If I do more than 13 PSI pressure in the WG the car cut the boost. One way to resolve this could be install the green spring and try put more pressure in the WG (14/15PSI). What do you think?
Thanks for your helping,
VS
Old Jun 1, 2012 | 09:41 AM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Use the green spring with no spacer.
cnebrask
Oct 3, 2024 08:19 PM
3WDistributing
31
Oct 27, 2017 01:26 PM
ECS Tuning - VW
Aug 25, 2015 11:53 AM
The Oss
Aug 24, 2015 08:19 PM
ModBargains
Aug 20, 2015 12:28 PM
