Brake Cel - Any suggestions?
Old Jun 17, 2012 | 05:11 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Just recently I've been getting a Brake Cel light pop up
It says "Service Wear On Brake Pads"
The OBC shows I need to check my brake pads
I plugged the car into the Durametric, and each time I click on the "brake tab" on the left side of the screen I get more warnings pop up
When I click onto another tab the warnings stop
When I click it again, the warnings pop up again
The additional warnings then show up on the OBC
What to do? What to do?
I've given a quick visual inspection with the wheels in place and the outer pads and the discs look ok
What should I do before starting pulling things apart?
Old Jun 17, 2012 | 05:46 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
check if one of the sensor on the pads is broken, i personnally would start wth that...
Old Jun 17, 2012 | 05:50 AM
ant_8u's Avatar
Is there anyway to narrow down which brake(s) could be at fault, or do I need to check them all one after another?
I'd obviously check them all anyway, but I'd like to get to the faulty one first if at all possible
Old Jun 17, 2012 | 11:13 AM
djantlive's Avatar
time to pull the pads out. start with the front (unless it's been replaced last 20k miles) and then check the rears.
the systems won't know which corner triggered the warning.
Old Jun 18, 2012 | 03:49 PM
ant_8u's Avatar
Ok, I've removed the wheels and have taken some measurements
Some things are obvious, but others still have me wondering......
Passenger Side Front
Disc = 33.02mm
Inner Pad = 5.66mm
Outer Pad = 5.71mm
Drivers Side Front
Disc = 32.85mm
Inner Pad = 4.56mm
Outer Pad = 4.44mm
Passenger Side Rear
Disc = 27.72mm
Drivers Side Rear
Disc = 27.76mm
According to the measurments in the workshop manual my front discs are only half worn, and my rear discs are pretty much new
I've taken some pictures so everyone can see what I'm working with, as despite what the workshop manual says, my rear discs are corroded as ****
Old Jun 18, 2012 | 04:40 PM
ant_8u's Avatar
Passenger Front Pictures
Old Jun 18, 2012 | 04:44 PM
ant_8u's Avatar
Drivers Side Front
Old Jun 18, 2012 | 04:48 PM
ant_8u's Avatar
Drivers Side Rear
Old Jun 18, 2012 | 04:50 PM
ant_8u's Avatar
Passenger Side Rear
Old Jun 18, 2012 | 04:53 PM
ant_8u's Avatar
Front discs look ok and measurements are ok
Passenger front pads look and measure ok
Drivers front pads look like they're getting close to the wear indicator, but measure ok
Rear pads look and measure ok
Rear discs look ****ed, but measure ok
Why are the rear discs so corroded?
Old Jun 19, 2012 | 05:06 PM
ant_8u's Avatar
Anybody?
I'm thinking I need front pads & sensors, and rear discs
A friend of mine said the rear discs are so new I could get them resurfaced?
Is that a sensible option or should they be replaced?
Old Jun 19, 2012 | 07:20 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
You should replace your front pads. They are getting low. I think that you can re-use the wear sensors, but I wouldn't swear to that. I tied mine off a long time ago.
No need to resurface anything.
Jon
Old Jun 19, 2012 | 07:43 PM
ant_8u's Avatar
Thanks Jon
I broke one of the front sensors whilst removing for the pictures so I'll replace those along with the front pads
Car is DD street use, so I'm looking at Mintex or EBC Redstuff pads - Sound ok?
Can you have a look at the last picture in post number 8 again - The rear of the discs is seriously corroded, but the discs are still ~27.8mm thick (new is 28mm)
Can the rear discs still be used, can this corrosion be rectified, or should I just replace them?
I've just been reading about bedding in brakes and glazed brakes
Are my discs looking too shiney/glazed or are they fine with the exception of the rear faces?
Old Jun 19, 2012 | 07:51 PM
pumalex's Avatar
are the rear calipers working correctly to give such a bad rust?
Old Jun 19, 2012 | 08:17 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
I wouldn't use Mintex personally, not a fan ...
Used them on my B5 Audi S4 and had fading issues during semi-aggressive driving on the street.
I purchased a set of Cool Carbon's for the 996TT but haven't installed yet You can search, they seem to have a very positive following.
Good luck.
Originally Posted by ant_8u
Thanks Jon
