What are the symptoms of a leaking brake booster vacuum?
Old Sep 7, 2013 | 09:38 AM
sexirob's Avatar
sexirob is infamous around these parts
I was just quoted for the complete vacuum line - $125. Ouch and all I need is that C-Clip......
Old Sep 7, 2013 | 12:20 PM
pwdrhound's Avatar
Make sure that on each caliper you bleed the outer bleed valve FIRST and then the inner. This is very important! Also bleed in this order: RR, LR, RF, LF. I bleed using the power bleeder but also pump the brake pedal (about 50% of full travel) 3 times per bleed valve. I always have a rock hard pedal using this technique and Endless RF 650 fluid (stock issue on Cup cars).
Feelgood MD
Mar 24, 2016 09:35 AM
Rockinc1
Sep 30, 2015 06:44 PM
yumaverick
Sep 2, 2015 03:48 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
