Short metallic sound on startup?
Took the car out for its first real drive including some fun mountain roads. Now, when I started the car, I heard a metallic sound that went away after a few seconds. Engine was cold and the car was parked on a relatively steep incline facing downhill.
Does this sound familiar to anyone? Could it be oil starvation from being parked on an incline? I guess it could also be the turbos that have wear but I'm not sure how common that is?
2002 996TT, bone stock. Fresh oil and filter and the oil level is just one bar under maximum. Any ideas?
I started the car about twice after that. All normal. This morning when I started in the garage, nothing either. Maybe it's fine, not sure? Just seems kind of strange; is this the Porsche experience?
there's no doubt, a strange oil starved kinda noise can occur if you park on a hill or incline. i heard it once recently and don't park like that any more. whatever wasn't being lubed for that millisecond, didn't like it either.
Car is a blast to drive btw! I'm actually impressed with the handling on stock suspension. I'll post some pics later too
sorry, off topic kinda..i was just talking with a fellow tt owner the oher day talking stock vs modded and we agreed we all think our cars are fast ( stock ) until we mod, once you add that easily available 100hp all bets are off. although, it's all relative. having said that, if i had only ONE thing and one to improve it would at least be suspension by way of lowering springs. VERY cheap, and a significant ( really ) improvement. h&r's are like 350 a set!
my driveway when the noise occurred is very steep and turn in is sharp also. i used to get abs/psm cels until i stopped friggin parking and 3 pt backing out. i don't park on that incline any longer and no more noise. was a ghastly metal on metal noise ( oil STARVED ) sound. if we both had the same sonic experience. either way, not a good or normal sound, to be sure. try and park and store it flat. h&r springs will help ya stay flat too. kidding...
Thanks! So, it sounds like that may very well be the issue then. Good thing is that the car is parked level in the garage at home. It's only when I take it out in the mountains that there is a very real chance I'll be parked on an incline.
I'm sure I'll get to suspension eventually . Won't you wear out the shocks quicker though if you use lowering springs? I have not researched anything about the suspension yet.
Starter problem?
Sounds like a starter problem. The sound comes right after you crank the car by turning the key right? For like 2 sec and then it goes away? A metallic grinding sound from the starter gear? I would take the stater out, clean it and reinstall. If problem persists, its time to replace it.
No you wouldnt....sometimes the starter gear and flywheel teeth will line up just right and everything will go off w/o a hitch. Problem is the more the problem happens the worse the condition gets.
Would it make a difference when the engine is warm or cold? Is this harmful to any other parts besides the starter? This didn't come up in the PPI but I guess you would only be able to tell if you heard the noise.
I still want to hear it first on some "level ground" startups before doing anything but would be interested in learning about a DIY as well.
Haven't searched for a DIY, but what i can tell you is that I had a new clutch kit installed 3 weeks ago, the starter was removed from the car as part of the clutch kit install. After the installation was complete, the grinding noise appeared which was never there before. 8 out of 10 times, the grinding noise was there. The shop told me they removed the starter, cleaned it and re-installed. Problem gone.
Thanks! Just want to get as much info as possible since I'm not sure if that is actually my problem. I will pay close attention each time I start the car (not that you can miss it).
