Moving on from 315/25-19s
Old Aug 3, 2012 | 11:21 PM
Turbo Fanatic's Avatar
Currently Selected Tire Size(s)
Size
Service Description
Load Range UTQG Max
Load
Max.
Inflation
Press.
Tread
Depth
Tire
Weight Rim
Width
Range
Meas.
Rim
Width
Sect.
Width
Tread
Width
Overall
Diam.
Revs
Per
Mile
Country
of Origin*
245/40ZR19
(98Y) XL 300 AA A 1653 lbs.
50 psi
10/32"
25 lbs. 8-9.5"
8.5"
9.8"
9"
26.7"
778
US 325/30ZR19
(105Y) XL 300 AA A 2039 lbs.
50 psi
10/32"
32 lbs. 11-12"
11.5"
13"
12.5"
26.7"
778
US
Old Aug 3, 2012 | 11:40 PM
dragonman4's Avatar
dragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond repute
Isn't 26.7" too high? I would run them but I have a feeling I would rub on my pss9's set to GT2 height.
Old Aug 3, 2012 | 11:44 PM
TekNiC3's Avatar
TekNiC3 is infamous around these partsTekNiC3 is infamous around these parts
225/40/19 in the fronts are very close for me in terms of rubbing when the steering wheel is fully turned (might even be rubbing, but I don't notice it). I checked the clearance right when I installed the wheels and it looks tight.
245/40/19 would be too tall for the fronts from what I can tall.
I have 305/30/19 on the rears.
Old Aug 4, 2012 | 02:40 AM
mitcho168's Avatar
mitcho168 is infamous around these parts
nice rims
car looks goood
Old Aug 4, 2012 | 07:15 AM
scottrx7tt's Avatar
scottrx7tt has a spectacular aura aboutscottrx7tt has a spectacular aura about
when i had 305/30/19s on my car, they rubbed the fenders, and the wheel liner because they were too tall. I had to buy some 305/25/19s pirellis clearanced on ebay. So im gonna guess that 325/30/19 is going to be worse?
Old Aug 4, 2012 | 09:56 AM
Kapoosh1's Avatar
Kapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura about
I'm using 305-30-19's in the rear now with no issues ...wouldn't mind trying a 325 the next time around....
Old Aug 5, 2012 | 12:43 PM
AutoTalent2's Avatar
AutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to all
Great looking wheels, we just shipped out a set to your area
Old Aug 9, 2012 | 02:06 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Yes, they're too tall. It depends on your specific suspension setup and the particular tire though since some may fit. I know most will not and will rub at full lock and/or at full suspension compression.
I'm still trying to find out whether I can run the 325/30-19 on the rear or not. I have stock suspension and 19" HRE P43R wheels. Anybody running this size on a 996 WB with stock suspension, either Turbo or C4S? Bueller? Bueller?
I'd run a 245/35-19 in the front to match with the larger rears. I get 22.376" for the total height of that front rim/tire combo versus 22.238" for the 235/35-19 size I'm using now, which I have absolutely zero issues with. I can't imagine the extra .138" will make a difference on clearance, but stranger things have happened!
Old Aug 9, 2012 | 03:00 AM
CharlotteGould's Avatar
CharlotteGould is infamous around these parts
agree
rob4wellness
Oct 2, 2015 07:32 AM
bzibi
Southwest
Sep 30, 2015 08:03 PM
