need some pics gt2 fuel tank area...
Old Sep 11, 2012 | 05:00 PM
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
Can someone from this forum can post some pics of the gt2 fuel tank (upper portion) with the black cover in the trunk removed... just want to compare something with mine...
Old Sep 11, 2012 | 09:25 PM
Tim941NYC's Avatar
it is the same as the turbo. as the c2 c4 gt3
Old Sep 12, 2012 | 06:38 AM
gclasse's Avatar
Well like the turbo, or the c2 c4 with the access below the battery tray... so they are nit the same
Old Sep 12, 2012 | 12:43 PM
jpflip's Avatar
You will found a lot of good pictures of the fuel tank from Pumalex here: https://www.6speedonline.com/forums/...-pictures.html
Old Sep 12, 2012 | 02:11 PM
Tim941NYC's Avatar
Ok I you are right good luck... The gt2 pump fits in the turbo tank. All the pumps are located under the plastic cover with the 4 nuts.. But your right
Old Sep 13, 2012 | 10:12 AM
gclasse's Avatar
Jpflip thanks for the info... i'll use as a guide to replace my pump... cause i'm having the same issue pumalex is describing...
Tim.... That is the thing.. to access the GT2 tank in my car, i need to remove the battery tray... Name:  20120912_205104.jpg
Size:  299.2 KB.. i will assume this is normal for GT2
Jul 29, 2019 11:13 AM
J9277655
Dec 28, 2015 11:01 PM
97GtsMonster
Nov 17, 2015 12:38 PM
turbotuner20v
Sep 11, 2015 12:02 PM
orbelo
Aug 30, 2015 12:26 PM
