GT2 Suspension vs. Upgraded 996TT
Old Sep 19, 2012 | 05:19 AM
  #31
Prche951's Avatar
Originally Posted by Turbo Fanatic
Let's get a bit more detailed here.
Are you saying that the yaw control comes back on with PSM off and the brakes applied? IE there is no intervention whatsoever when there are no brakes being applied, but once you apply the brakes, the PSM system will intervene to straighten out he car.
If so we are saying the same thing as what I stated above has been been my real world experience. You can do big time donuts, drifts, etc... with zero intervention from the PSM when it is deactivated. Hit the brakes though, and the car will come into line in a hurry.
Only the yaw sensor is active. So your car has to be pitching a lot for it to come into working. If you have a stiff aftermarket suspension, there is less intervention. I have yet to feel psm's yaw component involving itself after installing the PSS10 setup and stiff sway bars. But I am sure I will experience it at some point.
Old Sep 19, 2012 | 01:32 PM
  #32
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Originally Posted by Steve Jarvis
I'm curious what happens when I push and hold the PSM button for 10-15 seconds. The PSM off light on the dash goes on initially and then goes off after I hold the button for 10-15 seconds. After you have done this, you can't turn the PSM back on until you turn the key off and back on.
What mode am I in at this time? Could this be a way to completely disable PSM?
Just curious,
Steve
This is the first time I hear of this. 10-15 seconds press hold switch completely disabling PSM until key off/on? Did you go for a drive and can confirm PSM is off even if you engage brakes? Must try this...
Old Sep 20, 2012 | 08:00 AM
  #33
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
I haven't had a chance to test it. I just thought it was interesting that the light goes out after you hold the button for 10-15 seconds and you can't get it back on.
This is probably best tested on the track, but hopefully I get a chance to do some testing.
Later, Steve
Old Sep 21, 2012 | 01:16 PM
  #34
Prche951's Avatar
here is a few good vids of a mostly stock 996tt that with minor upgrades does quite well.
http://www.youtube.com/watch?feature...&v=JhkdWSiMaMo
Old Sep 21, 2012 | 02:01 PM
  #35
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
http://www.youtube.com/watch?v=uex0S...hannel&list=UL
Nice one.....rep point for that very much enjoyed. You did well. That GT2 was a bit jittery wasnt it
Old Sep 24, 2012 | 07:50 AM
  #36
Later, Steve
Here is a quick update.
After holding the PSM button for 10-15 seconds and getting the PSM OFF light to turn off, I believe the PSM is still on. At full throttle in 2nd gear, the PSM OFF light began flashing as the tires started to spin.
Apparently it doesn't disable PSM.
Later, Steve
Old Sep 24, 2012 | 08:52 AM
  #37
Terminator's Avatar
Later, Steve
I thought as much. Damn! I was looking foward to this one being a total disable. Porsche should have done it this way.
Old Sep 24, 2012 | 08:57 AM
  #38
Later, Steve
Thats the traction control side of it working .Even with PSM off you still get traction control but it doesn't intervene with the throttle/engine power.
If driving in snow its best to turn off PSM as PSM intervenes too much killing engine power to almost nothing. Snow.....some thing I'm quite used to driving in tbh.
With PSM off it is still active in the back ground but to a limited extent. If you do a fast lane change to avoid an accident for eg and the car gets out of control, PSM will intervene to try and correct the problem.
Its the control of the throttle angle that is the issue with PSM when on the track, the sudden lack of power if the rear end drifts. But its that very action that has removed the stigma of the 911 and 911 Turbo being a "Widow Maker".
I would much prefer a good LSD and the ability if required to completely turn off PSM on track days and have it 100% for road use. Just my take on PSM.
Old Sep 24, 2012 | 01:47 PM
  #39
Terminator's Avatar
I feel the same. On for the road and the ability to switch it off completely for the track. That would be ideal. But LSD would then be a must. Otherwise the car would be ridiculous to drive.
ECS Tuning - VW
Aug 20, 2015 02:01 PM
ECS Tuning - VW
Aug 19, 2015 02:36 PM
ECS Tuning - VW
Aug 19, 2015 01:23 PM
