Yet another dismantling question ;-)
Old Oct 25, 2003 | 06:04 PM
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
In the continuing saga of installing a two-way ham radio unit, I need to run a 1/4" diameter coax cable from inside the engine compartment to under the front passenger seat.
Inside the engine compartment, I figure the coax can follow the same wiring loom route as the harness from the electric cooling fan to the large rubber grommet inside the rear right hand side, just above the engine loom connectors.
Question is how to access it from inside the car ? The gromment seems to be behind the rear rhs air vent and presumably the cable loom makes it way to the ECU and other stuff (not sure where the ECU is located though).
I've removed the rear speaker box and can see a bunch of elecronics boxes under an aluminum sheet - not sure what that stuff does are where the cables are routed.
Any suggestions about the best route or means of remving panels for access would be great !
Thanks Tim
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
HotRod
Sep 10, 2015 07:17 PM
pjb84
Sep 2, 2015 12:57 AM
