Remove front drive shaft?
Old Oct 25, 2003 | 07:20 PM
bbeasley's Avatar
bbeasley is infamous around these parts
How do you remove the front drive shaft?
How would removing it affect the PSM in "Off" position when pushing the car hard (autocross)
I would love to be able to turn mine into RWD at certain autocross events (when the surface has great traction). This should help the car rotate better.
Old Oct 25, 2003 | 08:35 PM
cjv's Avatar
cjv
Moderator
Unbolt the plastic cover and remove. Unbolt the little U shaped metal guard over the part that bolts to the tranny. Tilt the U shaped part down. Unbolt the four bolts were the shaft meets the tranny and pull the shaft down and out towards the tranny. Rebolt the metal U shaped piece back up. If you have a lift it takes about fifteen minutes.
Old Oct 26, 2003 | 04:22 AM
Chris Y.'s Avatar
Chris Y. is infamous around these parts
Chad...
If you unbolt it and drive around, is the car drivable, or will it throw a host of warning lights???
Old Oct 26, 2003 | 07:29 AM
AMG ETR's Avatar
Originally posted by Chris Y.
Chad...
No lights, it is perfectly ok no harm just fun
Evan
Old Oct 26, 2003 | 07:36 AM
PorschePhd's Avatar
The lights will come on while on the dyno, but once the car sees all four wheels moving then the system will clear. It is not a permanent code and will clear immediately while driving unless you hang it out to far
Old Oct 26, 2003 | 12:15 PM
Chris Y.'s Avatar
Thanks guys...sounds like an experiment???
Does PSM still work with the driveshaft removed???
Old Oct 26, 2003 | 12:29 PM
AMG ETR's Avatar
I can let you know early this week, I am (finally) going to get my car dynoed, and I plan to take it out quick while it is disengaged..
Evan
Old Oct 26, 2003 | 01:12 PM
Chris Y.'s Avatar
Thanks Evan...Looks forward to seeing your Dyno results.
Old Oct 26, 2003 | 01:25 PM
AMG ETR's Avatar
Me too...have been at shop 3 times for other stuff, and we always run outta time to dyno...gunna try and get there tom., but the shop is an hour away...
Evan
Old Oct 26, 2003 | 08:28 PM
bbeasley's Avatar
Thanks Guys!
Evan, I can't wait to hear your 2wd report.
Old Oct 26, 2003 | 09:53 PM
PorschePhd's Avatar
The PSM in foward motion is shut down if it senses that the front wheels are not in control. The ABS will still function.
Old Oct 27, 2003 | 06:51 PM
bbeasley's Avatar
PorschePHD,
Does this mean you can stay on the gas and brake at the same time?
Thanks!
Old Oct 27, 2003 | 08:20 PM
Chris Y.'s Avatar
Huh??? Last I checked I could still heel-and-toe...
Originally posted by bbeasley
PorschePHD,
Thanks!
Old Oct 28, 2003 | 06:56 AM
bbeasley's Avatar
You can "Heel and Toe". However, If you attempt to stay on the gas and brake for more that a few tenths the throttle body closes.
I race autocross and this feature kills the ability to consistently "plant" the front end when you need to. You can experience this easily on the street by just pressing the gas and brake at the same time.
Old Oct 28, 2003 | 09:43 AM
Chris Y.'s Avatar
bbeasley...
thanks for the clear up. I've heard this discussed on the boards before and didn't quite understand what people meant about the TB closing down.
-Chris
Enemy
Nov 10, 2015 08:01 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
vr6tee
Aug 29, 2015 03:52 AM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
