What Should My Next Mods Be?
Old Oct 24, 2012 | 09:03 PM
scsponger31's Avatar
scsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to behold
So I am allowing myself to spend about $8k on the car. I have been doing tons of research and can't decide where I want to put the money. The big debate is handling vs. more power. I would love to hear your thoughts and opinions.
Old Oct 24, 2012 | 09:11 PM
johnspeed's Avatar
Tune, DV valves,exhaust and 997 short shifter for sure to start with..
You will get other's opinions and then do a search and compare notes..
Good Luck..
Old Oct 24, 2012 | 09:25 PM
Good Luck..
I have al of those mods, other than the short shifter, but I am stuck on what to do next.
Old Oct 24, 2012 | 10:01 PM
johnspeed's Avatar
You have to get that shifter, it will make the car so much more enjoyable..
Now bang for the buck is going to get costly for the return..
Maybe intercoolers next,those do work but more so if you ever go to bigger turbos or dealing with high heat.
Old Oct 24, 2012 | 10:16 PM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Short shifter is a great mod. GT2 clutch conversion is awesome mod. I would be looking at handling modifications if I were in your shoes, like some of the RSS components. Also some of the preventive maintenance might be a nice thing to throw a chunk of that budget at, like the water line mods. Keep the rest in your pocket for when you actually need it, or save for something you know you want without second guessing. Keep us posted on what you decided to do.
Old Oct 24, 2012 | 10:18 PM
Sounds like I need to do a short shifter. I have thought about having the coolant lines welded but have been putting them off.m
Old Oct 24, 2012 | 10:30 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Looks like you've already picked the low hanging fruit on both the power and handling side. More power past the tune and exhaust gets expensive quick. Hybrid turbos with bigger intercoolers. Hopefully GIAC will cut you a break on an updated tune. Depending on your boost goals you'll have to decide between 997.2 IC's or all metal aftermarket ones (at twice the price). For sure do the 997 short shifter, solid rubber motor mounts (Suncoast sells a kit) and 997 tranny mount. These are all easy DYI. Suspension could use some firming up. Consider rear dog bones, adjustable toe links, drop links and sway bars. I'd hold off on the coolant fittings and GT2 slave conversion until you need a clutch (or a fitting you can't get to blows). Pulling the engine isn't cheap.
Old Oct 24, 2012 | 11:28 PM
I like the way you worded my current mod list!
How much power can stock clutch handle? Should I be upgrading that before IC's and turbos?
Old Oct 24, 2012 | 11:49 PM
sharkster's Avatar
I'd add a set of these to the list:
http://www.sharkwerks.com/products.php?pid=335
Old Oct 25, 2012 | 12:14 AM
Turbo Fanatic's Avatar
Are you running stock non X50 K16 turbos?
For 8K you can probably get power and handling mods if you do it right.
The fuel system will get you to the limits of pump gas with 5 bar fuel pressure regulator.
I woudl say get:
Upgraded Turbos (you can get your turbos hybridized)
5 BAR FPR
997.2 IC (used)
Coil-overs
Rear Sway Bar (H&R)
15mm spacers all around
Alignment with more front camber
Voila. $8K. max power (600-650HP), max handling on a budget!
Personally, I removed the engine mounts and light weight flywheel after paying buying them and paying to get them installed. They were too much compromise for my taste.
Old Oct 25, 2012 | 04:18 AM
32krazy!'s Avatar
danny did you get the pop out fixed? if not fix that and weld the coolant lines. add a numeric racing short shifter and send the k24 to blouch for rebuild. while the engine is out air intake lines and injectors for the k24 turbos. that should eat most of the cash up and set you up for a long run with little issues
Old Oct 25, 2012 | 10:32 AM
I woudl say get:
5 BAR FPR
997.2 IC (used)
Coil-overs
Rear Sway Bar (H&R)
I still have the stock Turbos. Can the stock clutch handle the added power from the bigger turbos?
Pop out is fixed
Old Oct 25, 2012 | 01:14 PM
32krazy!'s Avatar
if you have the gmg build you have oem k24 as an upgrade from the k16. send them to blouch or go alpha 28 clucth is going to be needed if you push the car hard
Old Oct 25, 2012 | 01:46 PM
While under the car I wrote down this part number that was on the turbos, part # 5324-101-5075. I can't figure out if that is k24's or not. I may have call GMG and see I they have records on the car.
Old Oct 25, 2012 | 02:31 PM
johnspeed's Avatar
Hey, I might be upgrading to Tial Alpha 3071 from my present Blouch K24/18g's ?
