Major differences between n/a 3.6 in 02+ 996 and 02+ 996 turbo?
Old Nov 4, 2012 | 03:25 PM
RyanZ06's Avatar
RyanZ06 is infamous around these parts
I searched breifly, but is there a website that possibly outlines the differences in these engines? Are the piston and rod kits available from tuners like EVOMS and Vivid racing capable of being installed in these n/a variants? What about the cylinder heads and cams? Obviously the compression is much higher on the n/a unit, but is that due to piston design or head design? Port differences?
And lastly, are the transmissions the same? (i know the n/a variants to not include a rear LSD).
Old Nov 4, 2012 | 04:14 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Two totally different engines and transmissions.Parts are not interchangeable.
Old Nov 4, 2012 | 04:18 PM
VAGscum's Avatar
The only similarities are that they are both six cylinders, 3.6l and horizontally opposed. That is the only similarities. Completely different. The turbo and gt3 engines is closer to older aircooled engines with water jackets and the 3.6 liter carrera engine is completly new engine designed in a joint effort with the Japanese.
Old Nov 4, 2012 | 05:40 PM
RyanZ06's Avatar
so the n/a is not based off the mezger platform?
Old Nov 5, 2012 | 01:23 PM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
No, the N/A is not based off the Metzger motor. The Turbo is, as well as the GT3. They are two very different engines.
Old Nov 5, 2012 | 03:15 PM
slavik's Avatar
slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !
they are two completely different animals...really not comparable-as others have mentioned engine,transmission are completely different
Old Nov 6, 2012 | 05:27 AM
RyanZ06's Avatar
thanks for the input guys!
Old Nov 6, 2012 | 06:45 PM
Nor Cal Turbo's Avatar
Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !Nor Cal Turbo Is a GOD !
Yes very different engines. I've owned both. To put it simply, The mezger engine is basically better in every single way than the n/a engine.
Oct 6, 2015 05:20 AM
Aug 19, 2015 06:55 PM
