996tt Single Turbo Conversion
Old Nov 15, 2012 | 01:46 PM
UAE996TT's Avatar
UAE996TT is infamous around these parts
Nutcase although my self not convinced with single turbo if you believe in something go ahead and try it and don’t let others let you down . this is why other cars like GTRs reached 1000+ hp faster than 996TT and 997TT because most of us don’t take initiative and try different things and don’t push it to the limit and if somebody fails we stop at that point and most of us think this is the limit for a long time till somebody has courage comes and go beyond this limit and most of us copy and follow till next stop
Old Nov 15, 2012 | 03:15 PM
ard's Avatar
ard
Originally Posted by Nutcase
If im correct, two turbos rated at 500hp will spool a bit faster and have a more linear power curve, but one 1000hp turbo will be more efficient and see more power to the ground.
So go with two 510HP turbos... solved.
Old Nov 15, 2012 | 05:25 PM
Tim941NYC's Avatar
1 turbo to push 1000 hp. gt42 or bigger. that about 8-9inchs around. Hell I wanted to do it but the twins made better sense to me. Also dont forget that the intercoolers split the duty of of cooling the air but then the bigger turbo will heat the air less. you got me thinking again.
Old Nov 15, 2012 | 07:32 PM
Nutcase's Avatar
Nutcase is infamous around these parts
UAE996TT: Thanks for the kind words, but closed minded opinions dont scare me hehe. Ive always tried to push limits with cars where i can, and somtimes just build things that havent been done. The Porsche is new to me, but its still just an engine with wheels like every other car ive worked on.
Tim941NYC: gt42 was exactly what i was thinking of.. to begin with anyway
As for intercoolers - instead of air to air look at water to air. Ive used it on many other builds. If its setup correctly on the porsche it leaves you with loads more room to play with, shorter intake path, etc.
I think im going to start doing some measuring this weekend and im very seriously considering going ahead with the single conversion. Tim, Ive seen your thread and the pictures of your build and I love your work. I'd really appreciate any ideas or input you may have.
Cheers.
Old Nov 15, 2012 | 10:58 PM
UAE996TT's Avatar
Nutcase keep us posted .. good luck
Old Nov 16, 2012 | 06:32 AM
Nutcase's Avatar
Will do mate, but this may take some time - im busy as hell.
On a positive side, I just organised a gt42/45r from my mate. I bought it for him ages ago, it was for his v8 soarer that i was building but the project got put on hold and its been sitting there for years now.
And so it begins..
Old Nov 21, 2012 | 10:57 AM
Man_Car's Avatar
Man_Car is infamous around these parts
And so it begins..
Let us know how it goes. I know the Supra guys are fans of the single over dual setup.
Old Nov 21, 2012 | 12:16 PM
a lot of that has to do with space and plumbing room. problem with big turbos is just that - they are big and need space, bigger downpipes, bigger intake plumbing, bigger outlet plumbing. tough to make it work on a supra with two big boys.
#TeamAIM
Old Nov 22, 2012 | 10:28 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
I think going to a single would be a downgrade. I know guys with big v8s that want to go to twins for the quicker spool time. My buddys rb26 with a 67mm has retarded lag. Stick with twins
Old Nov 26, 2012 | 01:02 PM
JETmn's Avatar
JETmn is infamous around these partsJETmn is infamous around these parts
All real world tests I have seen there are very little difference between the 2 setups. A single is slightly better than twins though. Spool is slightly better on a single IF plumbing can be kept to a minimum (LS series is where I have seen most of the comparisons). That is the problem I see with the 996 is trying to get it to fit.
I also have been seriously looking at air to water IC's. It should work great in the 996tt! Keep us posted on any mockups or anything, I was to see what you come up with.
Old Nov 26, 2012 | 10:06 PM
Tim941NYC's Avatar
water to air adds a lot of weight plus it gets hot and never cools back down in the streets. How much Ice can you carry for how long??
Old Nov 26, 2012 | 10:19 PM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
Best wishes to you NutCase...innovation is always a good thing for the community. Best wishes to you for this ambitious project.
SharkyShark20
Sep 19, 2015 09:54 PM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
TrackOne
Aug 20, 2015 12:56 PM
