Carrera SII rims on a 996 turbo 57/67 offsets will it work
Old Nov 25, 2012 | 08:51 PM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
Hi all, been searching the forums for an answer and can't quite find a for sure one.
I have a line on Carrera sII 19 inch rims 8x19x57mm offset front and 11x19x67mm rear offset.
Will this fit a 996 wide body Turbo? If not, what is the needed spacer.
Any help on who is running this set up would be greatly appreciated.
Thanks in advance.
Old Nov 26, 2012 | 04:55 AM
32krazy!'s Avatar
spacers will be needed. your looking at about 20mm to deep an offset. i just installed new wheels with 40 et front and 45mm et rear and have no issues but the rear is tight maybe 3 to 4 mm clearance
Old Nov 26, 2012 | 04:05 PM
rangerdick's Avatar
Steve, Thanks for the info. After alot of searching, I figgured these were the narrow body rims and would require spacers and the purchase of new rear tires, so they were not the deal they appeared to be. BTW, still working on datalogging with the durametric.
Old Nov 26, 2012 | 04:18 PM
32krazy!'s Avatar
i think i have the durametric figured out. i ordered the forgestar cf5 wheels and mounted 315/30-18 and 235/40-18 pzero tires. perfect fit zero rub and fender flush! the 40et front 45 et rear is the bomb!
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
