Which New Top Mounts?
I'm finally fitting the KW Manthey Clubsports to my car
The Manthey versions were originally designed for the GT2, but I'll be fitting these to my Turbo
I've got the Sleeves/Spacers needed from JRZ, and have been speaking with Ira at Tarrett regarding which Drop Links I'll require
My next question before fitment is regarding top mounts
I know I have to use Turbo top mounts to ensure the correct angle of fitment
BUT, should I use OEM, or KW uniball topmounts
AND, do I require any other bits and pieces in order to fit the topmounts to the coilovers?
Here's some pictures showing the coilovers
Will the top mounts fit straight on, is everything I need there, or do i need any other attachements/spacers/ washers etc, etc........
