OEM Fuel Return line - E85 Safe?
Old Jan 23, 2013 | 09:20 AM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
Currently I am running a dual 044 setup with the stock pump feeding the sump. With all these fuel prices, thought I switch things up a bit and tune for E85.
My return line is nearly 100% stock and I was worried if I run E85 fuel could cause problems. Any thoughts?
Thank you
Old Jan 23, 2013 | 08:38 PM
Ms4cd's Avatar
No one knows?
Old Jan 24, 2013 | 06:43 AM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Mind sharing some pics or info on your 044 setup?
Old Jan 24, 2013 | 07:16 AM
i dont see why it would cause problems. most cars of that generation are deigned to accept fuel with Ethanol content. On another note it is pretty easy replace the return and you should be returning to your sump anyway rather then the main tank.
#TeamAIM
Old Jan 24, 2013 | 08:41 PM
Ms4cd's Avatar
Here is my setup, trying to make sure long term all would be OK running E85.
Old Jan 24, 2013 | 08:44 PM
Ms4cd's Avatar
Closeup while being installed.
tropicatango
Jun 8, 2025 01:00 PM
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
orbelo
Aug 30, 2015 12:26 PM
