All of a sudden the windows aren't working
Old Jan 29, 2013 | 09:02 AM
cburke996's Avatar
cburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of light
Recently my passenger side window stopped dropping down to allow the door to open/close, so I ordered a new micro switch. This weekend I removed the door panel to install it, only to realize I didnt have the right tool to remove the latch assembly...its called a triple square?
So I just reassembled my door panel and will pick up the tool to complete the job. But now all of a sudden neither of the window switches work... I'm wondering if a fuse blew out, havent checked yet. Has this happened to anyone else though? Wonder if its a coincidence that this happened after door panel removal or not. Any help is appreciated.
Thanks,
Connor
Old Jan 30, 2013 | 11:31 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
There's a dyi out there, I try to find it.
But are you sure it's not the door latch mechanism that failed?
If you pull the door handle just slightly and you hear the micro switch clicking, chances are its the door latch mechanism.
I had this same problem.
Old Jan 30, 2013 | 11:34 PM
gearhead's Avatar
I bumped my old post to help you out.
Plus it has the links to remove your door panel. Good luck.
Old Jan 31, 2013 | 06:54 AM
32krazy!'s Avatar
it is a triple square . i found a nice set on ebay for about 20$
cinellipro
Dec 20, 2017 07:12 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
r_matt_6
Oct 8, 2015 06:07 PM
gulf gt
Aug 27, 2015 10:27 AM
