greetings and upgrade question
Old Oct 29, 2003 | 07:48 AM
franki68's Avatar
franki68 is infamous around these parts
hi ,new member just thought id say hi,and ask if anyone knows the best place to get my TT's engine upgraded in the Uk ?
Old Oct 29, 2003 | 08:25 AM
Joe Weinstein's Avatar
It depends on how much you want to do.
The first stage is typically to put a freer-flowing
exhaust and get your ECU flashed/replaced.
Any trustworthy mechanic can swap your
exhaust (see europipe.de), and a monkey with
a 10mm socket wrench could remove the ECU.
You could then choose to mail it anywhere in the
world to get programmed.
Joe
Old Oct 29, 2003 | 08:26 AM
Duane's Avatar
Duane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud of
Start with an exhaust an divertor valves.
Old Oct 29, 2003 | 08:32 AM
TSP-MIAMI's Avatar
TSP-MIAMI is infamous around these parts
Franki, Contact G-Force racing. They are an authorized RS-Tuning facility in England. Really good shop, great reputation and products.
Theo
Old Oct 29, 2003 | 08:45 AM
msindi's Avatar
BTW - the url for that exhaust is europipe.be not .de....
Old Oct 29, 2003 | 09:22 AM
ooops, yes www.europipe.BE !!
The other one is good if you want sewer pipes...
Old Oct 29, 2003 | 09:45 AM
franki68's Avatar
thanks for the advice,the next question is how reliable are they,an exhaust and ecu re-programming are as much as i would want to do.(our roads aren't as long in the uk )
Old Oct 29, 2003 | 09:50 AM
do three things...
Do the diverter valves as well as exhaust and chip.
The valves are cheap to do and remove the failure-
prone stock ones. No real power difference (until
you compare against stock failed ones;-) ).
The exhaust will be the only real cost. You can get
your chip done for that level of modification by Upsolute
for about $500.
Joe
Old Oct 29, 2003 | 09:55 AM
TSP-MIAMI's Avatar
With G-Force/RS-Tuning, you have the very best on what is available. They have years of experince in the TUNING/RACING prep and service for P-cars in England.
You will be happy there.
Theo
Jul 29, 2019 11:13 AM
COBB Tuning
Nov 9, 2015 08:02 PM
vr6tee
Aug 29, 2015 03:52 AM
tkeck3
Aug 25, 2015 02:52 PM
