Cold start issues - Lumpy idle bucking, trying to stall
Old Aug 15, 2013 | 08:37 PM
  #31
Rich L's Avatar
Rich L is infamous around these partsRich L is infamous around these parts
Originally Posted by mrmaass
Which gasket on the throttle body, if you don't mind me asking? Was it the short length of tube that connects the Y-pipe to the T-B? I can see how this could be "folded over" if the clamp comes off.
I don't know for certain, but I know it was on the y pipe side of the throttle body. My Indy just explained it was leaking badly when pressure tested and was "folded over".
Old Aug 17, 2013 | 02:40 AM
  #32
Shantybeater's Avatar
Shantybeater has a spectacular aura aboutShantybeater has a spectacular aura about
Hi Bruno, got your PM but felt it would be better to add to the thread
The issue doesn't appear to have progressed at all, i was hoping to get some warning lights at some point but nothing.
Symptoms: I start the car, it sounds ok on choke but when switching to warm idle it struggles, sounding a bit like some old v8, then it settles and drives ok but a bit sluggish, once warm she is 99% ok, the only thing I notice is if I rev at a standstill it sometimes falls below what you'd expect but never stalls
I'm leaning towards an exhaust/air leak somewhere or old coilpacks. I've logged the car on the durametric and I am seeing misfires, more so in one or two cylinders but this goes once warm. Planning on delving in and doing a big refresh at some point when I get a chance: coils, sparks, compression test, IC piping, F pipe, exhaust etc...if this doesn't fix it I will get a smoke test carried out. Will update the thread when I find out more
Old Oct 21, 2013 | 12:31 PM
  #33
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
Were you ever able to figure out the issue?
03EvoIII
Sep 21, 2015 04:38 PM
turbotuner20v
Sep 11, 2015 12:02 PM
Rez90
Aug 24, 2015 09:53 PM
magoochi
Aug 23, 2015 05:54 PM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
