Power Steering Leak! HELP!!
Old May 6, 2013 | 07:42 AM
Yazz911TT's Avatar
Yazz911TT is infamous around these parts
Hi Guys my car has the GT2 Slave conversion, its been fine for 18months, but last night one of the pipes started leaking real bad. I nursed her home, I was only 5miles away. Had enough fluid not to run the pump dry. I cannot find the part number for this pipe for the life of me. Please help!
The pipe that is split and leaking......
Old May 6, 2013 | 08:04 AM
rmc1148's Avatar
Go to autoatlanta.com they have great pics with numbers in parts. Hope this helps
Old May 6, 2013 | 08:39 AM
wross996TT's Avatar
PN 99631426902 pressure line (item 16)
Old May 6, 2013 | 09:21 AM
jpflip's Avatar
Hum...I removed a bit of contrast from the picture and the arrow seems to be pointing towards the middle rigid line.
Name:	Capture d’écran 2013-05-06 à 11.19.37.jpg
Old May 6, 2013 | 09:26 AM
jpflip's Avatar
If it is the middle line which is rigid, it is a long line going to the slave (gt2 conversion ?) ....Part# 996 314 280 03 supersede by part#99631428004 $79.75 at Sonnen. Must be a very good job to replace.... Is this line still in used with the GT2 conversion?
Name:	Capture d’écran 2013-05-06 à 11.23.13.jpg
Old May 7, 2013 | 03:07 PM
Yazz911TT's Avatar
JP flip the pipe u identified in your edited pic is indeed the one i require. it does not go to the slave cylinder. it is a power steering pipe.
Old May 7, 2013 | 11:10 PM
smith564's Avatar
smith564 is infamous around these parts
Old May 9, 2013 | 09:01 AM
jpflip's Avatar
Very hard to see on the parts catalog. I am trying to locate the other two lines going to the steering rack but it is very difficult. According to this drawing items 8 and 9 are steering pressure and return but the shape of them seems to be different....The black line has to be return....
Name:	Capture d’écran 2013-05-09 à 10.53.58.jpg
ID:	241104   Click image for larger version
Name:	Capture d’écran 2013-05-09 à 10.57.08.jpg
Michael_s
Sep 11, 2015 08:03 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
Zero911
Aug 24, 2015 06:51 PM
JMon
Aug 21, 2015 08:20 AM
