Strange car behavior need help
Old May 7, 2013 | 08:27 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
The other day driving my tt I was entering my neighborhood and decided to do a late brake and stopped very aggressively before turning in to subdivision. No lockup or skid but noticed psm/ abs light came on and stayed on. I drove to house and turned off car. A couple days later I went to drive car, no lights remained lit and car drove fine for about 5miles and boosted fine during those miles. I did however attempt to stand on it on the way back home and noticed that my boost was limited to .4 or so and was puny. I noticed that not only that but if I floored the car it would not downshift (tip) or boost over .4 or so. No lights present. Parked car and had no time to fool with it. I went to drive it again a week or so later and car cranked up but idle was a bit erratic but stayed running, as I tried to give the car some gas in park, the engine would not respond at all only idled. I do now have a check engine light (not blinking) and a message to drive to workshop. Any simple diagnostic I can do as if car won't respond to throttle input it can not be driven. This happened before and ended up being ecu was fried from a battery charger mishap. Any suggestions? I thought about unhooking battery and letting car reset itself and see what happens. I am concerned about being away from home driving and then the throttle stops responding and I am stranded needing a rollback. I have not checked codes as I do not have a code reader. I would love to borrow one and would be happy to rent it to diagnose. Please help.
Old May 7, 2013 | 08:39 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Maybe the F hose popped off. Check all the hoses. Something is probably loose.
Old May 7, 2013 | 08:45 PM
silver's Avatar
I will try to check it soon. I wonder if a hose came off of the intercooler also? Would I have heard a noticeable wooshing when it was still boosting? I did feel what felt like a stumble for a split secong but that is just before I noticed car would not downshift. Anything else to try or look at?
Old May 7, 2013 | 11:37 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Defiantly check hoses. Check right off the turbo hose.
Old May 7, 2013 | 11:46 PM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
When it happened to me it was a split F hose, limited boost to 0.7 bar, I found it doing a leak pressure check. Check all the push in hose connections; the lower inter-cooler connections have popped out on my friend's car.
Old May 8, 2013 | 04:24 PM
silver's Avatar
Big props to Blackhorse turbo and others who suggested hose. It was in fact the F hose came off of the big connection. It looked like it was on but further inspection revealed that it had popped off and was just butting up against connection and not on it tightly clamped. All is back on and tight. Should I unhook battery and let ecu reset itself or should I be good to go when I crank the car?
Old May 8, 2013 | 05:35 PM
32krazy!'s Avatar
should be fine. what part of the southeast are you in?
Old May 8, 2013 | 06:04 PM
silver's Avatar
I am in Augusta, GA. I just cranked car and it started fine. Idled ok seemed normal with a little up and down but not stalling or needing to be kept running. The throttle is still unresponsive. Idles but no response to throttle input. Should I unhook battery, or go through several start cycles. The check engine light is staying on. So something must still not be right. Any thoughts or suggestions?
Old May 8, 2013 | 06:25 PM
pat's Avatar
pat
Check the bottom hose and others just to be sure. Maby more then one hose was off. All should have worked fine after you put the f hose back on. Make sure there is not another one off.
Old May 9, 2013 | 08:04 AM
I'm glad it was a simple fix. No need to unhook the battery. Just plug and go!
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 09:56 AM
