Sunroof memory problems
Old May 19, 2013 | 04:27 AM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
Originally Posted by mikerosi
Boys, boys, boys...........forget the rain sensor its not connected to the sunroof motor LMAO.. After talking to several people the concensus is that the motor contains the circuit board and memory function...So I am changing out the motor and will let you guys know how it goes, I know, I know...But what if it snows!!!!!!!
Sorry guys for making a SH*$ sandwich, just wanted to inject a small joke about the memory thing. Glad most of you got it.
The snow memory is related to the PSM/ABS sensors in the wheels. If they detect 4 different wheel speeds, it tells the sensors there is snow on the ground and the sun roof will also open.....
Old May 27, 2013 | 09:54 AM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
Guys we have a SOLUTION. My sunroof motor was bad. Apparently the memory is contained in the motor and now everything works great after replacing the motor.......
Old May 27, 2013 | 10:04 AM
XLR82XS's Avatar
Great! Did that solve any issues with the 1-touch open close feature? Sometime when closing my sunroof with 1-touch it will close halfway then open again.
Old May 27, 2013 | 10:52 AM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
Glad you got it fixed. Sounds like it was the same thing as mine. Now, about that rain sensor.....
Old May 27, 2013 | 11:38 AM
mikerosi's Avatar
Yes it solved all the problems. Everything works like new, Mike
Old May 27, 2013 | 05:13 PM
Aerodude's Avatar
Did you replace it yourself or have it done at a shop? Just curious how easy (or hard) it is to do in case I have this same problem in the future.
Old May 27, 2013 | 06:26 PM
BiteEmNBeatEm's Avatar
BiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud of
glad it worked out!
Old May 28, 2013 | 08:29 AM
mikerosi's Avatar
I changed it myself, VERY easy; 2 bolts, remove from gear casing, unplug harness..............thats it. Mike
NC 996TT
Mar 23, 2023 06:19 AM
jonate24
Oct 25, 2015 11:34 AM
jaehoppa
Oct 22, 2015 09:17 PM
Vrrooom
Sep 15, 2015 02:03 PM
