All-Aluminum Radiators
Old 07-08-2013, 01:04 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
the 'snap'-in water necks could easily be made, but also to note that with a longer slip-over style water necks on the new rads(like the cup car rad. shown above), the factory hoses appear to be able to be modified(cut the metal ends off and just slip the remaining rubber hose over the new rad. straight neck) to work with the 'conventional' hose clamps/slip style fitting..
Old 07-08-2013, 01:15 PM
rmc1148's Avatar
I've cut Audi hose ends off and done as 993gt suggests.
Old 07-08-2013, 01:37 PM
XLR82XS's Avatar
Originally Posted by prodigymb
I always found it srange noone has made a radiator upgrade.
Something in the works.... be patient and I'll report soon.
Old 07-08-2013, 01:41 PM
993GT's Avatar
Are you talking about the companies I have contacted or do you have something in the works?
Old 07-08-2013, 01:44 PM
bbywu's Avatar
how much are the cup car ones?
Depending on where you source them, as low as $750, as high as $850.
Old 07-08-2013, 01:47 PM
993GT's Avatar
Good to note. If nothing happens with the aftermarket rads soon, I will probably pull mine off and have my buddy make and weld on some end-tanks with basic water necks and cut the hoses to fit.
Old 07-08-2013, 04:41 PM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
Yes please
+1 for an all Aluminum option. I blew both the front left and right at different times at the track, and one was at 155mph approaching the end of a straight. It got "intresting" with fluid all over the windshield and more importantly under the tires. It was a good thing there was a run off area.
The stock end tanks simply split their seams at the junction of the plastic and aluminum after some years.
Old 07-08-2013, 07:48 PM
Tim941NYC's Avatar
I have seen them. I will find out tomorrow who is making them. I thought it was C&R..
Old 07-08-2013, 09:04 PM
dubyaTT's Avatar
dubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of light
I have seen CSF and GSR offerings for the non turbo cars before.
I think TPC or Tarrett sells them.
Hope that helps.
Old 07-08-2013, 09:38 PM
993GT's Avatar
there are indeed aluminum rads for the N/A 996's, Pelican has had them a long time....would be neat to see if C&R is making them(TT), and for how much $$$
Old 07-08-2013, 09:54 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
Surprised to hear there are none available. Same problem with BMW; the radiator neck gets brittle with age and can break off. I bought an all-aluminum one for the bimmer.
Old 07-09-2013, 08:10 AM
XLR82XS's Avatar
That would be great as I could hold off on development if it's a quality product.
Old 07-09-2013, 08:11 AM
XLR82XS's Avatar
Something in the works unless Tim finds a quality source.
Old 07-10-2013, 10:54 AM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
Yes, GSR does make all-aluminum rads for the 996. For further product details, click here.
No fabrication is required, a direct bolt-on to the stock location
CNC machined mounting locations for perfect fit for all factory components
Utilizes CSF's B-tube technology for 15% increase in efficiency
Innovative swappable fitting design allow single radiator to work on the left or right side of vehicle
Made from military spec aluminum to resist damage and withstand up to 50% higher pressure over stock
Perfect upgrade for street or track applications
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old 07-10-2013, 10:56 AM
We also offer a pretty good write-up on the removal and installation of the radiators for your reading enjoyment!
Replacing Your 996 Radiators
Mark/Pelican Parts
Quick Reply: All-Aluminum Radiators
