996 turbo ECU died
Old Jul 22, 2013 | 04:55 AM
adelino's Avatar
adelino is infamous around these parts
996 turbo ECU died
Hello,
For no reason, my ECU just stopped comunicate with the obd port, and the car doesn´t start.
I ear the fuel pump working, but the engine doesn´t start.
It´s strange, because i think the pump is controlled by the ECU, but my Porsche dealer says he can´t connect to the ECU...
help please!
Old Jul 22, 2013 | 05:37 AM
rmc1148's Avatar
The Porsche dealer should be able to answer the question as well as anyone here if not find another dealer/indy shop.
Old Jul 22, 2013 | 04:00 PM
Macster's Avatar
Originally Posted by adelino
Hello,
help please!
The ECU doesn't have to communicate with the OBD2 connector to control the engine.
Obviously many many vehicles (like all of them) work just fine with nothing connected to the OBD2 port/connector.
Is the CEL on?
What are the symptoms of the no start condition?
Old Jul 22, 2013 | 06:25 PM
you connected some after marker reader to the obdII port.. you maybe damaged something in the process.. I recall you saying you did just that...
why did you connect that cable? for what purpose? what were you trying to do?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 22, 2013 | 08:46 PM
adelino's Avatar
Hi mark, i've tryied to flash the ecu, but with a cable that wasn't apropriate (an friend lend me a vag113 to see if it works) and i couldn't connect because i hadnt the drivers. But after that, the car ran prperly for 200miles+ with stops and startings.... it wasn't even on the same day... do u think it had something to do with it? If so, can i do anything to reverse it?
Old Jul 22, 2013 | 08:54 PM
rmc1148's Avatar
I'm curious adelino what the dealer did as far as trying to connect to the ecu and did he offer a suggestion as what should be done/ looked at next etc.
Old Jul 23, 2013 | 04:50 AM
adelino's Avatar
Hi,
When i connect to the obd2 port, not even the guys from the oficial Porsche dealer, can connect to the dme. That´s why they say i have to have a new one installed
Old Jul 23, 2013 | 05:22 AM
nimski62's Avatar
nimski62 is just really nicenimski62 is just really nicenimski62 is just really nicenimski62 is just really nicenimski62 is just really nice
Did you check all fuses?
Old Jul 23, 2013 | 05:31 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Like I said before sounds like your ecu is toast. Never stop in the middle of a flash.
Old Jul 23, 2013 | 07:06 AM
rmc1148's Avatar
If the dealer or a good independent shop cannot come up another answer your ecu as said above probably will have to be replaced.
Old Jul 23, 2013 | 07:10 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
I second this.
Old Jul 23, 2013 | 08:23 AM
adelino's Avatar
yes, i´ve checked all fuses.
I didn´t started to repro, because my cable wasn´t apropriate.
After i tried the unappropriate cable, the car started fine and ran for more than 200 miles (starting and stopping several times).
So... new ideas!!! please!! (sorry for being anoying.... but... i just can believe the DME is toasted!!!)
Old Jul 23, 2013 | 12:04 PM
32krazy!'s Avatar
send the dme to your tuner or epl and let them look at it in detail. this should tell you what you want to know
Old Jul 23, 2013 | 12:20 PM
sinKing's Avatar
When you had that relay issue not too long ago were you able to connect through the OBD?
Old Jul 23, 2013 | 02:25 PM
32krazy!'s Avatar
no my inability to connect thru the obdII came after i swapped dme to another prepped unit as the consenus was the dme had an injector driver burnt out in it.( chasing misfires at the time) turns out i had a bad cyl 1 injector. im receiving a new file this week from epl and ill be trying to connect again thru the obdII . strange thing is my durametric cable works flawless. the tuner bench checked my laptop, cable and both dme's i had with no issues
the relay i had replaced caused the car to act like it was immobilized. all accessories would work ie: radio , lights ect. but key would yield nothing when turned except a cel light. the dealership determined a relay in the dme area had burnt and replaced it. i never was able to get a part # or accurate description of what exactly was replaced
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
Aug 19, 2015 06:55 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
