Clutch Pedal Stuck To The Floor
Old Jul 24, 2013 | 07:28 AM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Jumped into the car last night, stepped on the clutch, and it snapped to the floor. Popped it back up, but it feels as if there's nothing attached to the pedal. Under the dash seems to be connected properly, nothing fell out to the carpet. Fluid levels are good, and no leaks under the car. It's not the accumulator, because I had the GT-2 conversion done last year. Haven't got up under the car, but is there linkage that may have come undone above the under body panels? Anyone else with this same problem? Searches here seem to refer back to the accumulator, but that's not the case here. Thanks.
Old Jul 24, 2013 | 08:15 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Can the car go in first gear and drive it? if not you broke the TO bearing or fork not cheap to fix. 2k to 3k for labor and parts how old if your clutch?
Old Jul 24, 2013 | 11:30 AM
drug delivery's Avatar
drug delivery is infamous around these parts
It's those mismatched tires you used. You said so yourself not to do it.
Sorry, had to get that in.
I recently did a clutch upgrade and GT2 slave swap. There are enough stories on here about issues with this I keep waiting for something to fail. Curious to see the verdict with your car.
Recently had my car at the dealer for a window issue and they thought my TO bearing was bad. They didn't know I have a single mass fly wheel that rattles. They quoted nearly $5k for the work, which included a new clutch.
Old Jul 24, 2013 | 12:28 PM
johnspeed's Avatar
Most likely I think it's the slave..
Old Jul 24, 2013 | 12:44 PM
uschoice's Avatar
Must have been someone else with the mismatched tires. Still have the stock sizes on mine.
I wasn't aware of the GT2 slave conversion being prone to problems. I researched it for a while before doing it, and only hear people praising the new experience.
Got to watch those dealers! $5K for work not even needed is horrible.
I'll post what happens. I may just cut to the chase and have the car brought to a shop.
Old Jul 24, 2013 | 12:46 PM
uschoice's Avatar
Compared to a new TO bearing, pressure plate or fork, the slave would be good news. I'd consider doing that myself.
Old Jul 24, 2013 | 12:48 PM
uschoice's Avatar
I was able to shift into the gears with the engine off. Don't want to try it with the car running while its parked in the garage.
Old Jul 24, 2013 | 01:51 PM
996tt550hp's Avatar
Yes but if it doesnt shift into gear when the car is on its the TO or fork. It doesnt sound like the slave because you would have leaks or no fluid upfront.
Old Jul 24, 2013 | 02:01 PM
johnspeed's Avatar
A slave doesn't have to leak to be
bad.
Old Jul 24, 2013 | 02:08 PM
996tt550hp's Avatar
bad.
The chances of it going then is nill to nothing his signs are not a slave problem its internal. I had the same problem.....
Old Jul 24, 2013 | 02:15 PM
Must have been someone else with the mismatched tires. Still have the stock sizes on mine..
That was for 996tt550hp from another thread.
Old Jul 24, 2013 | 04:19 PM
johnspeed's Avatar
Mine went bad and didn't leak.
Old Jul 24, 2013 | 06:35 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
That is what happens when the slave fails almost exactly...you sure there is no fluid anywhere? Could be hiding
Old Jul 24, 2013 | 06:54 PM
johnspeed's Avatar
Believe it or not but my Accumulator is what leaked,,the O ring seal went bad..
Old Aug 16, 2013 | 02:52 PM
uschoice's Avatar
OK, here's the short version update; hate to leave these posts unanswered. The slave and master both went bad. There were never any fluid leaks, or reservior level changes. Had BBi near me do the work.
If you are ever in need of any type of work done, go to Betim and company. Absolutely awesome customer service and workmanship.
