Tire help, big time!
Old Aug 9, 2005 | 10:46 AM
DrJim's Avatar
DrJim is infamous around these parts
After speaking to damon at the tire rack, I might go with Pirelli's that make a 305/25 in 19's. I know alot of people don't like Pirelli's but is there anyone out there who does? It's the P Zero Asymetrico. FWIW, the 305 is closer to stock than the 315 in all dimensions.
Old Aug 9, 2005 | 11:48 AM
drbill's Avatar
drbill is infamous around these parts
Originally posted by HotRodGuy
, that's a joke right?
not a joke. i admit it..i punctured my radiator on my ferrari the first time i jacked up the car....
Old Aug 9, 2005 | 12:13 PM
HotRodGuy's Avatar
hey, on the bright side, atleast you won't make that mistake again. We've all had one of those
Old Aug 9, 2005 | 01:02 PM
drbill's Avatar
agreed. I will certainly never forget the jack point on my car!
Old Aug 9, 2005 | 02:36 PM
DrJim's Avatar
I was there and it was painful to me watch it happen. I ordered the Pirelli's in 305/25 for the rear and 225/35 for the front. I will certainly report how they feel compared to the outgoing Yoko's. I'm hoping for a more compliant ride at the expense of ultimate grip.
Old Aug 9, 2005 | 03:34 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
you may want to look at one of these before you install your new tires. i just ordered one myself. i can never tell if my tires are low just by looking at them and i've accidentally run at some lower than optimal tire pressures. if you order the remote display, you can hide the dorky looking unit under your dash and place the remote wherever you want it. the remote is pretty trick. displays real time tire pressure, temp, and has programable audible alerts. might as well do it now while you're having the tires changed. tirerack sells them too, but vulcan has them on sale.
http://www.vulcantire.com/smartire_pass_sys.htm
Old Aug 9, 2005 | 05:06 PM
mpwrmodena's Avatar
mpwrmodena is infamous around these parts
The pirelli makes great tires for cornering, they wear well also. Then again Ive never used Yokos so I cant compare.
Old Aug 10, 2005 | 05:37 AM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
Just curious if there's anyone who has/is run the 305/25 on the 19?
Old Aug 10, 2005 | 06:40 AM
i do right now. i'm getting rid of them though.
Old Aug 10, 2005 | 06:53 AM
damon@tirerack's Avatar
Moderator
If anyone like the SmartTire TPMS system, we have them available as well. $229 for the basic system, and $49 for the remote LCD Display. The LCD display shows realtime temps and PSI on all four corners and can be easily tucked up under the dash. Check it out at:
http://www.tirerack.com/accessories/...artire_all.jsp
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Aug 10, 2005 | 09:25 AM
DrJim's Avatar
Dang Damon, I would have grabbed that yesterday but wasn't thinking of it. My tires were on the UPS truck locally at 7:30 AM this morning and I should have them shortly so thanks for your help and quick service.
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
MrMiggy
Aug 21, 2015 06:55 PM
