Low boost 996 Turbo
Old Aug 8, 2013 | 05:20 AM
Mr.Black's Avatar
Mr.Black is infamous around these parts
Low boost 996 Turbo
Hello from Russia)
I need your help!
Auto (996 Turbo S) does not given a boost after the chiptuning! Blows is 0.9 bar
There is a new exhaust with 200 cel cat.
There are no errors! No leakage!
What it can be?
I have 2 versions:
The first version about detector N75, it was removed and given voltage , it works! May be stuck during overboost?
The second version about MAF, how to check it? We removed the connector from it, nothing to changed! Auto has been to go worse or not?
Very interested your thoughts and advice! What it can be?
Sorry for my English)))
Old Aug 8, 2013 | 09:14 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Boost leak/Markski
Old Aug 8, 2013 | 10:27 AM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Get a duramitric and get it checked. I had an issue where it would go into "limp mode" it would not boost over 0.4 where normally it would boost 1.0 with my flash.
Turned out to be broken wires on the engines knock sensor. But there was no lights on the dash to show there was a problem but the durametric picked it up.
Old Aug 8, 2013 | 11:56 AM
who flashed the car? often the EURO black market sells unknown tunes... be careful...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 19, 2013 | 02:23 AM
Mr.Black's Avatar
The problem has not gone! I put the chip from another company (USA), nothing has changed! The car goes the same that before the chip and after.
There are no errors! There are no leakage! I tested the car in two services, but found nothing.
I can not understand, why nothing no changes after the chip? Car rides are not better and not worse, should not be the errors pressurization?
Is there any chance that the program is not recorded and it is the problem with ECU?
Old Aug 19, 2013 | 02:40 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
do a diagnose log with durametric and test requested boost vs actual boost and you became a answer to your boost setting at ecu programming and situation over your engine management
Old Dec 12, 2013 | 07:26 AM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
Originally Posted by gearhead
Get a duramitric and get it checked. I had an issue where it would go into "limp mode" it would not boost over 0.4 where normally it would boost 1.0 with my flash. Turned out to be broken wires on the engines knock sensor. But there was no lights on the dash to show there was a problem but the durametric picked it up.
I'm having a problem with a knock sensor on bank 2.
Edit: fixed!
BlackMarketRacing
Dec 8, 2015 01:49 PM
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
