Bilstein PSS9
Old Aug 30, 2013 | 07:25 AM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
Bilstein PSS9
So I have this suspension set-up on my car. I am ok with the ride, however I keep reading all these threads about what settings to have them on for street v track and ride v performance.
It has made me curious what mine are set at.
How do I tell?
its and 03 996tt
Old Aug 30, 2013 | 10:09 AM
Th_Dude's Avatar
Th_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond repute
There is a round **** (about the same diameter as a nickel) that is used to adjust the settings. The **** has numbers etched into it. Look for a fine line on the edge of the strut to see which number lines up....that is your current setting.
On the front struts, the **** is on the bottom of the strut. You will likely need a mirror (or get the car into the air) to see the front settings.
On the rear, the **** is located at the top of the struts. You will need to remove the bose subwoofer box (remove speaker trim ring and loosen screw beneath) to see the tops of the struts and the adjustment ****.
Old Aug 30, 2013 | 10:18 AM
stilov's Avatar
That's why!
I was looking for the reverse! Bottom on rear, top on front.
RajuPatel
New Member Introductions
Oct 2, 2015 03:28 PM
ELMEL
Sep 28, 2015 01:12 PM
bongnation
Sep 25, 2015 02:58 PM
Zero911
Sep 24, 2015 06:33 PM
JWrightPNH
Sep 14, 2015 01:15 PM
