Daedalus 996TT Build Thread - RUF/ADV.1/Rottec/AP
Old 10-08-2013, 06:49 PM
930chas's Avatar
930chas is a name known to all930chas is a name known to all930chas is a name known to all930chas is a name known to all930chas is a name known to all930chas is a name known to all
Your car turned out phenomenal! That interior is the bees knees.
  #47
Old 11-01-2013, 11:43 AM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Got the 2nd seat put in. Took the belts out from routing through the top portion of the seat and only through the bottom and it's perfect. Very comfortable and easy to use.
Also got the custom caps in from ADV.1. They look SAWEET!
  #48
Old 11-02-2013, 08:42 AM
googone20's Avatar
googone20 is on a distinguished road
Amazing job! This is the exact color combo I am looking for right now. I am a sucker for a 996tt in Speed Yellow.
  #49
Old 11-26-2013, 03:05 AM
XwalkerX's Avatar
XwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud of
how does it look with the wheels on?
  #50
Old 11-26-2013, 08:06 AM
antagron's Avatar
antagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant future
How did the Agency Power air intake turn out? I am thinking about doing that, but I'm not sure how well it fits and if it really does anything aside from look cool in carbon. My car has some fancy aftermarket red turbo hoses and I'm not sure it will fit right.
  #51
Old 11-26-2013, 09:43 AM
daedalus's Avatar
The PSS's were on backorder so they didn't get installed before the snow fell so we'll have to wait until spring to see the wheels. I've got the car prepped for a full paint correction over the winter and sending the headlights off to be refinished to look new again as the next project.
Haven't got the intake in yet either so i'll update this thread when I do that install as well (probably nearer to spring).
  #52
Old 11-26-2013, 09:47 AM
antagron's Avatar
Does anyone else reading this thread have experience with that intake? Supposedly an extra 10-ish HP and it definitely looks cool being carbon. But I'm concerned I'd take something that works just fine and "mess it up"
  #53
Old 11-26-2013, 11:03 AM
Freier's Avatar
Freier is on a distinguished road
this project turned out great. Really like the Ruf front bumper...
  #54
Old 02-16-2014, 09:50 PM
daedalus's Avatar
Small update:
Headlights have had the UV layer fail in certain areas (it lived in Las Vegas for most of it's life) and my attempts to refurb them have been unsuccessful. I don't feel comfortable aggressively sanding them down and am going to leave it to the pro's. Based on some recommendations from members here i'm sending them out to http://www.innovativedetailing.com/ for their Level 3 refurb service. I sent them an email to inquire about the cost and got a call the next day from the owner who was very knowledgeable and helpful. Anyway - thus far i'm very impressed so far.
I will be touching up all the rock chips on the car, sanding them down, re-applying, etc until they are filled in flat and then doing the entire paint correction on the car over the next 2 weeks so it's done and looking good by the time the headlights get back. More pics of the touchups/paint correction coming soon!
  #55
Old 02-16-2014, 10:31 PM
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
Car looks great man! Headlights are not that difficult! I just did the ones on my cayenne to remove stone chips from the lenses! I had to go down to 600 grit to get them out! Took like an hour and a half for each one but they came out like new! I went "All wet sanded" 600, 800, 1000, 1500, and 3000 and then buffed the shi t out of them with my rotary buffer and some 3M compound! One tip is every time you change sand paper grit to go the opposite direction! I go from vertical to horizontal with each grit change! Its pretty hard to mess them up! Worse case you will just be sanding on them a long time!
  #56
Old 03-11-2014, 12:15 PM
daedalus's Avatar
Got a few work in progress shots from Innovative Detailing today. What happened to my lenses was actually the OEM UV coating had failed and been removed in parts of the lens, but not other parts which is why I thought it was clear coat overspray.
Anyway, they stripped them down and made them look like new again. These are going over to get a new UV Laminate applied over the top of them today to protect them from any future failing and rock chips.
Doing a full rock chip touch up to the entire car the last few days and got a few more days to go which i'll post up before/afters shortly.
Then just need to do the paint correction and get my wheels installed finally.
ID:	345189   Click image for larger version
ID:	345190   Click image for larger version
  #57
Old 03-14-2014, 10:20 AM
daedalus's Avatar
Day 186: Headlight Restoration
Ok so my headlights were in awful shape as the before pictures directly below will indicate. The original UV coating had failed (the car lived most of it's life in Vegas getting a lot of sun before I purchased it). My attempts to remove it had failed and the levels of correction needed weren't something I was comfortable with. Based on a similar thread by FI_FTW he recommended Innovative Detailing to do his repair and raved about the results so I contacted them.
Dave, the owner called me the next day and explained the options and what he thought was wrong with them based on the pics I had sent him. The price was more than reasonable and the work they did (not to mention documenting the entire process for me) and calling me to update me on it numerous times was more than impressive. I cannot say enough good things about Dave or the company so if you have similar looking lights - check them out here: www.innovativedetailing.com or www.headlightlensrestoral.com
Anyway - they are on their way back to me now and I can't wait to get them back in. It's been an embarrassing part of the car for me until now so i'm glad it's finally fixed and brought back to life.
Onto the pics!
Before:
Correction:
ID:	346767   Click image for larger version
ID:	346768   Click image for larger version
ID:	346769   Click image for larger version
ID:	346770   Click image for larger version
ID:	346772   Click image for larger version
ID:	346773   Click image for larger version
ID:	346774   Click image for larger version
ID:	346775   Click image for larger version
ID:	346777   Click image for larger version
ID:	346778   Click image for larger version
ID:	346779   Click image for larger version
ID:	346780   Click image for larger version
ID:	346782   Click image for larger version
ID:	346783   Click image for larger version
ID:	346784   Click image for larger version
ID:	346785   Click image for larger version
ID:	346787   Click image for larger version
ID:	346788   Click image for larger version
ID:	346789   Click image for larger version
  #58
Old 03-14-2014, 10:21 AM
daedalus's Avatar
Continued....
After:
Applying 3M:
All Done!
Paint correction next week and wheel install (and some CF goodies) the following!
ID:	346791   Click image for larger version
ID:	346792   Click image for larger version
ID:	346793   Click image for larger version
ID:	346794   Click image for larger version
ID:	346796   Click image for larger version
ID:	346797   Click image for larger version
ID:	346798   Click image for larger version
ID:	346799   Click image for larger version
  #59
Old 03-14-2014, 01:31 PM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
Smart they did the clear film, the UV spray doesn't seem to work as well.
  #60
Old 03-14-2014, 02:34 PM
birgppa's Avatar
birgppa is on a distinguished road
Ruf really made a homerun with this bumper, I have it too and love it. Any plans on getting the rear-wing? It's awesome
Quick Reply: Daedalus 996TT Build Thread - RUF/ADV.1/Rottec/AP
