Transmission issue
So I talked to a guy at a local shop today and based on my description, he said he thinks it's a synchro issue.
Didn't see too much in the Knowledge thread, the closest was a Gbox detent install on RT and there was a short throw shifter install for a Cayman (the comment said it was a similar process for a 996), but that one was old and the pictures/write up were no longer there.
if you read from the many extensive threads on 2nd gear popout, that will apply to your situation since you're gonna need 1st/2nd and the synchros replaced for each since those two gears and parts interact the *most*. a few grand at a bare minimum.
the gbox detent and all that isn't going to help you. sorry to say.
So I've had my car for about two months and so far, it has been running great. Recently, I was at a light and put it into first gear and started to accelerate when suddenly it felt as though the shifter was physically punched out of gear.
It has happened a few times, completely randomly. Has anyone had this issue? Am I just not fully putting it into gear? Is it a sign of worn synchros? This is my third consecutive car with a manual gearbox and have not had this issue, so I'd like to not think I'm a bad driver.
It's a 2003 Turbo for reference.
It's a 2003 Turbo for reference.I have had the same thing happen. Honestly, it feels like it is dropped completely in first but it actually isn't and when it pops the sound it makes is scary. Personally I have found it can be controlled by ensuring the delivery into first is complete by dropping into second first and then dropping all the way into first. There is a sweet spot you can feel when it drops all the way in. Since performing this manuever I have never had the issue. It might just be me and the way I shift the car, but I plan to have my indy check the cables on my upcoming oil change, just to make sure things are kosher.
Well, I got the car checked out today at the shop I mentioned and they didn't think there was an issue. They recommended swapping out the tranny oil with Swepco. That was about it. I'm relieved and I guess slightly embarrassed because I guess I just need to be more thorough with engaging first gear.
I drove the car a handful of times this weekend and today and haven't had the problem happen.
i certainly hope you don't have a problem, and have shared my horror stories with a bad gear, but the truth is, any popping out of gear in this car is portentous and foreboding. perhaps it will never happen again, but that isn't likely if it is an intermittent gear issue. i'm also not surprised that absent being able to replicate the ( non? ) issue at the shop, your indie suggested flushing the gear oil. that will certainly make for smoother and more certain shifts and they can't tell ya sh*t beyond that if it doesn't *happen* then and there.but if it POPPED out of first? like you said earlier, it will happen again. at least with fresh gear oil, it won't STICK in 1st with engine OFF in 33 degree temps! lol
gl w it! maybe it was nothing
that would be great
you guys shouldn't have to do anything special to engage or stay in first gear. i'm having difficulty even imagining not knowing when properly in 1st! i don't remember first gear engagement being on the learning curve but if it is for you, no harm/foul. maybe your gear oil was 10 years old. that's definitely not like a hot knife thru butter either
that would be great
that would be great
Well, I'll see how it goes and if anything else happens, I'll definitely take it back to the shop.
Hah I agree. That's why I thought it was an issue. I've been driving manual cars for almost 7 years now and also ride a motorcycle, so engaging first gear is nothing new.
you'll know what to do! again, GL!
LiquidElephant
Aug 27, 2015 06:17 PM
PelicanParts.com
BMW Vendor Classifieds
Aug 25, 2015 03:55 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
