Key Fob Issue
Old Sep 19, 2013 | 07:54 PM
Valley996TT's Avatar
Valley996TT is just really niceValley996TT is just really niceValley996TT is just really niceValley996TT is just really nice
It sounds like the fuse in the security module located under the driver's seat has popped. It is a little 15 amp blue fuse. If you can't turn your alarm on/off, open your door with the remote and the front trunk/bonnet will not open then I would check that fuse. My popped and did exactly the same thing yours is doing. A few expensive trips to a Porsche mechanic and a long 300+ mile drive to a Porsche dealership in S.A. didn't solve the problem. I found the popped fuse myself, changed it and the problem was solved. It is easy to get to once you remove the driver's seat. Good luck.
Old Sep 19, 2013 | 09:10 PM
gottspd's Avatar
gottspd has a spectacular aura aboutgottspd has a spectacular aura about
Try spraying the inside of the remote with plastic safe electrical contact cleaner. Mine does this from time to time and it always fixes it....
Old Sep 20, 2013 | 06:25 AM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
Originally Posted by '02996ttx50
does the light still blink red on the fob? mine did even with dead guts.
Yes, the light on the fob still blinks.
Old Sep 20, 2013 | 06:26 AM
I can't open the door or trunk with my remote.
Old Sep 20, 2013 | 06:27 AM
I'll give it a shot tonight.
Old Sep 20, 2013 | 08:12 AM
BW Copeland's Avatar
BW Copeland is infamous around these parts
996 Key fix/ replacment option
The key on my 996 Turbo began acting up then pretty much came apart in my hand a few cycles later. I search around and found this option. $112 and 10 minutes to fix. You have to pull the transponder from your original key and insert it into the new key fob. It looks like a gray tic tack. Super easy.
http://www.suncoastparts.com/category/996ttkeys.html
Old Sep 24, 2013 | 09:15 AM
Using electical contact cleaner didn't work.
I'll try moving the transponder into my other key tonight.
I'm trying to keep this updated for future searchers.
Later, Steve
Old Sep 26, 2013 | 02:38 PM
I moved the black pill into my new key with no success. I even did the unlock the door with the key, turn on the ignition and push the button on the fob program process with the new key/old pill with no success.
I'm not sure how this would work, but it was worth a try.
When I switched the guts out of my old key into my new key, but forgot to move the pill, the keyless function would work, but it wouldn't start the car. Given this, it would appear to me that the pill is specifically used to sync with something in the steering column and has nothing to do with the keyless operation.
Later, Steve
Old Sep 27, 2013 | 08:58 AM
Slider's Avatar
Correct - Pill and radio transmitter are totally independent.
Old Sep 28, 2013 | 10:11 PM
Urban's Avatar
Urban has a spectacular aura aboutUrban has a spectacular aura about
Mine died last week and I tried everything but nothing worked. My last resort is the new style fob from suncoast. If that does not work then I guess the stealer will get my hard earned money.
Old Sep 30, 2013 | 08:11 AM
I know that a new fob will not work without being programed by the dealer.
Later, Steve
Old Nov 8, 2013 | 08:10 AM
You have to move the transponder from you old key fob to a new one. It look like a small black tick tack. I do mine in 2 min and it works great
Old Nov 8, 2013 | 08:11 AM
Sorry typing on a phone equals crappy grammar
Old Nov 8, 2013 | 08:12 AM
Dang phone typing. Sorry for the grammar
Old Nov 9, 2013 | 08:36 AM
'02996ttx50's Avatar
a new fob will not remedy failed "guts". ever take a look at that circuit board inside? that they have even lasted 10+ years is the real mystery lol
