PSM/ABS Help code 4340
All,
I have read through a few previous threads on this, but can't seem to fix it and neither can my tech. We replaced the brake stop sensor, but the code 4340 keeps randomly throwing. It generally throws once the car gets on the highway and is just cruising speed. Any ideas on what this might be?
thanks in advance for any thoughts.
JSJ
JSJ
i have changed presseure sensor , abs sensors and i still get the lights and codes sometimes. i just give up until the middle of the winter and im gonna drop it off so they can go threw it. ill keep you updated if i find anything out good luck
Thanks Guys! the MAF was cleaned and appears to be ok. We've changed all the other sensors and stop light switch. We think it is the control unit itself so that's going out today to see if we can fix instead of replacing. Will keep you updated
Hi. Have exactly the same problem. Did you ever resolve the issue and if so how?
PelicanParts.com
997 Vendor Classifieds
Oct 5, 2015 01:07 PM
