Car not taking any gas..
Old Oct 22, 2013 | 12:22 AM
jpflip's Avatar
Charcoal canister location: Right hand wheel well, aft end under the plastic lining.
Name:	Capture d’écran 2013-10-22 à 02.19.50.jpeg
ID:	292040   Click image for larger version
Name:	Capture d’écran 2013-10-22 à 02.19.17.jpeg
Old Oct 22, 2013 | 12:25 AM
enoyskt's Avatar
enoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to behold
Ahh.. Looks like a easy replace. Is it that one nut holding it on there jpflip? Also, Would I need 99620122107 or 99620122109 ? There are 2 Number 1s. Thanks
Old Oct 22, 2013 | 12:46 AM
jpflip's Avatar
Sorry , got no experience with this item. I just tried both numbers with Sonnen and they both works???? And the 99620122109 as been replaced by 99620122108....But my guess is the second one is the right one. M664 means, Onboard Refueling Vapor Recovery (ORVR)...Once you got the wheel well lining removed you will get all the plumbing, vent lines, gate valve etc. that are part of the fuel system. May be you will found something else at fault.
Old Oct 22, 2013 | 12:47 AM
enoyskt's Avatar
Thanks for the info jpflip
Old Oct 22, 2013 | 08:54 AM
jpflip's Avatar
Wish you good luck with this troubleshooting. If you found something please share since this problem seems to be happening more often lately...
Old Nov 19, 2013 | 06:21 PM
enoyskt's Avatar
Ending up fixing this.
There is a low voltage wire that goes to a valve that opens the neck up for gas. Mine was not getting anymore power after it went into the firewall. Mechanic ran a new low voltage wire from fuse to valve and all is good again.
Old Nov 19, 2013 | 07:36 PM
jpflip's Avatar
Wow!! I am impress!!! Good job enoyskt!
PorscheEnthusiast
Nov 13, 2015 02:23 PM
gulf gt
Aug 27, 2015 10:27 AM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
DerekShiekhi
Other British Cars
Aug 19, 2015 05:25 PM
Nissan GTR
Aug 19, 2015 02:11 PM
