Radiator leaking….
Old Nov 3, 2013 | 08:50 AM
jpflip's Avatar
Radiator leaking….
Every year I'm removing the front bumper cover for radiators clean-up. Since I had a strong coolant smell every time I was driving the car hard decided to pressurized the coolant system. With 15 psi found a leak at the top of the driver side radiator. Can it be fix or I need a new one? part# 996-106-131-72 supersede by 996-10-131-74 ($573.50 ouch!)
Name:	Capture d’écran 2013-11-03 à 10.44.32.jpeg
ID:	296012   Click image for larger version
Name:	Capture d’écran 2013-11-03 à 10.44.41.jpeg
Old Nov 3, 2013 | 09:55 AM
rmc1148's Avatar
I would replace as they usually end up leaking elsewhere better to fix it once lol.
Old Nov 3, 2013 | 10:06 AM
scsponger31's Avatar
scsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to behold
How did you pressure up the system? I need to do this as well.
As for the radiator, I would replace it. Then you don't have to worry about it.
Old Nov 3, 2013 | 10:09 AM
jpflip's Avatar
I got a Blue point radiator pressure kit SVT275-1….Good product...
Old Nov 3, 2013 | 11:27 AM
95RogueM3's Avatar
95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of
Check out FCPEuro. I bought all (3) of my radiators last year (1 was leaking...I replaced the other 2 as preventative maintenance) from them. I think each of the side radiators ended up being $350 or so and while not an OEM Porsche part...its the same manufacturer.
Old Nov 3, 2013 | 11:48 AM
jpflip's Avatar
Thanks for the info!!!
Old Nov 3, 2013 | 02:59 PM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
I also bought mine from FCP last year. Good price there and they are all OEM.
Old Nov 3, 2013 | 06:07 PM
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
I will need to be doing this soon myself! Anyone ever had the center one leak? I am wondering if it is just the side ones that have the problem? Is there anyone that makes an upgraded setup with different end tanks? I would prefer something better then the OEM as they aren't worth crap!
Old Nov 3, 2013 | 08:15 PM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
Sorry to hear this JP. From what I have looked into, the radiators should be viewed as a scheduled replacement item. My TT had it's side radiators replaced at 38,000 miles and 9 years age. Don't know how to fix. Maybe epoxy and a press to seat the tanks? Good luck.
Old Nov 3, 2013 | 09:29 PM
I've have 42k on my 03 and driver side is leaking very slightly!
Old Nov 3, 2013 | 10:21 PM
jpflip's Avatar
I'm looking at different avenue right now, of course a new one is the better option but replacing the front radiator is not a bad job and getting it fix is tempting…But My car is over 12 years old now, may be it is time to simply replace it. And next year the other one
Old Nov 4, 2013 | 11:03 AM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
We offer the AKG brand radiators for your TT if considering a new replacement. You may find the left side here: AKG Radiator Porsche 996 TT
Sorry about the leak and good luck with the replacement DIY, it'll be a snap!
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old Nov 4, 2013 | 11:12 AM
jpflip's Avatar
Thanks for the info Mark. It has to be close from the OEM because mine is engraved AKG on the top plastic part ;-)
Old Nov 17, 2013 | 02:31 PM
jpflip's Avatar
Update: I went to see a welder that a friend suggested and this guy saw a problem with my radiator almost immediately. Where the leak was, the plastic cover was not equally press down on the radiator. We use a special tool to bend the clips properly at the leaking area and did a pressure test at 10 pounds in his garage and no more leak….Once home I did the same thing on both faces of the radiator all around both covers and after the radiator reinstallation, got the PST2 out and did, for the first time, the "Special function" called "996 turbo cooling" that is used to bleed the TT. This function delay the fan operation and the temperature of the system is aloud to go up to 210 F ! This function takes about 20 minutes to do with the engine running and help you to fill the system properly. I did it twice to be sure and there was no sign of leaks anymore…. I did a good inspection of all three radiators and there is no sign of corrosion on any of them and I think it was worth trying to save it…. Will keep you updated on that one
Name:	Capture d’écran 2013-11-17 à 16.06.27.jpeg
ID:	302206   Click image for larger version
Name:	Capture d’écran 2013-11-17 à 16.06.39.jpeg
ID:	302207   Click image for larger version
Name:	Capture d’écran 2013-11-17 à 16.06.50.jpeg
ID:	302208   Click image for larger version
Name:	Capture d’écran 2013-11-17 à 16.07.08.jpeg
Old Nov 18, 2013 | 09:38 AM
Thanks for the update, looks like you solved that issue.
Mark/Pelican Parts
