Frustrated with radio code issue.
Old Nov 4, 2013 | 07:01 PM
zracer196's Avatar
zracer196 is infamous around these partszracer196 is infamous around these parts
Hi all,
Just got the car. Dealer (not a Porsche dealer) installed a new battery and apparently did not have the codes (PCM and NAV).
Drove the car home 500 miles with no radio not stressing about it. Dealer is paying for issues. Had the car gone through at a local independent shop. Car is in wonderful shape but they also cannot figure the code issue out. Multiple Porsche dealers have given us the same codes to no avail.
Anyone know where to go next for help? My Indy shop said they know a radio ahop who knows oem radios. Hope that works.
Thanks in advance!!
Old Nov 4, 2013 | 07:15 PM
XwalkerX's Avatar
XwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud of
i purchased my turbo used and never had a radio code either...
found this website.
worked perfect for me.
hope it helps you
http://a2dvoices.com/realitycheck/porsche/
Old Nov 4, 2013 | 07:24 PM
zracer196's Avatar
Thanks Xwalker...It is at the shop until tomorrow. I have the VIN here...I guess I can try that for now. Do you have the NAV unit? I do...It requires the PCM and NAV codes to work.
The dealer(s) have given me the same codes to use using the VIN method. But not working.
Old Nov 4, 2013 | 07:27 PM
XwalkerX's Avatar
oh bummer. i dont have the OEM nav unit just the CDR-220
Old Nov 6, 2013 | 08:57 AM
Slider's Avatar
It's a 4 digit code with no lockout for repeated failures. Do you have children?
If your car is 2001, you will not be able to get a Nav update anyway. I went through considerable trouble finding a car with Nav only to find out (after) that you can't get updates. I ended up replacing the OEM with Pioneer.
Another trick - many owners put the code under the ash tray - have a look.
Old Nov 6, 2013 | 10:57 AM
zracer196's Avatar
Thanks Slider...At this point my funds are going other places (Speedtech, Softronic, etc.) ! LOL! Just wanted some music for now...Hopefully it can be figured out by the dealer.
Old Nov 6, 2013 | 09:21 PM
drug delivery's Avatar
drug delivery is infamous around these parts
Loren over at Renntech helped me out. There's a big thread over there to ask for his help on this specific issue; see link. You'll need the Type number (4 digit) and serial number. There's a way to get this from the display but I don't remember how.
http://www.renntech.org/forums/topic...-request-here/
I don't know if the 997s onward have this issue but it's a serious PITA for the 996 model.
Old Nov 6, 2013 | 09:57 PM
zracer196's Avatar
Thanks!! I will be calling him tomorrow...I have that info.
Old Nov 7, 2013 | 07:33 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
On my 2001 I ended up replacing the entire audio system, its near impossible to get the codes working good luck !
Old Nov 7, 2013 | 10:24 AM
zracer196's Avatar
Thanks...So far I just got the radio code from Becker...Now I need the NAV code (was told by Becker that Siemens handles that part).
Crazy...
Old Nov 7, 2013 | 02:27 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
Good luck - this is one of the dumbest issues Porsche ever came up with. Was there once a huge rash of crappy stereo thefts in Germany?
Old Nov 8, 2013 | 01:49 PM
zracer196's Avatar
Got lucky apparently...Dealer pulled radio and found code card taped to the top of the radio! All is good!
Funny as it was different than the code that Becker gave me via the serial number.
Whatever...At least it works now!
Thanks for all advice...
BLKMGK
May 31, 2016 04:32 AM
kkswow12
964
Sep 11, 2015 10:31 PM
Yogi911
Sep 9, 2015 08:20 PM
