Tire Size for 18x9
Old Nov 22, 2013 | 07:07 PM
rabbit1445's Avatar
rabbit1445 is a jewel in the roughrabbit1445 is a jewel in the roughrabbit1445 is a jewel in the roughrabbit1445 is a jewel in the rough
Tire Size for 18x9
After searching, I have not found a definite answer as to whether or not a stock size 225/40/18 will appropriately fit a 9 inch wheel. Tire manufacturers list this tire fitting up to a 9 inch width, so I would imagine it would have no more stretch than the oem 295/30 tire has on the stock turbos 11 inch wide wheels. Anyone have any experience with this?
Old Nov 22, 2013 | 07:28 PM
dubyaTT's Avatar
dubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of light
Will it fit on the wheel? Yes.
-I would not want to be the guy mounting it though.
Will it work? Probably.
-The question then becomes...why?
Old Nov 22, 2013 | 11:02 PM
rabbit1445's Avatar
I was looking at a set of wheels that are 18x9 and 18x11. I've got a new set of stock size tires and wanted to know if the front would fit and retain the matching rolling diameters for the awd...
Old Nov 23, 2013 | 09:30 PM
ard's Avatar
ard
If the tire manufacturer specs up to a 9" rim, then you are good to go. Diameters will not vary much.
I run a 265/35-18 on a 9" rim, but could run the 235/40 on it. both of those fronts are a match for the 315/30 rear. which you can run on that 11" rear rim.
COBB Tuning
Nov 9, 2015 08:02 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
