Chasing a CEL + misfire, please help
Old Jan 6, 2014 | 11:39 AM
  #31
mrmaass's Avatar
mrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond repute
Update
Well...the misfire never came back, but the p1145 came back right on schedule after 3 days. I was watching the ST fuel trim on both banks with my new PLX gauges and I noticed that bank 0 would sometimes just stop moving and hold at 0 while bank 1 was always moving slightly up and down as it should. The CEL would occur soon after bank 0 fuel trim stopped moving.
Last week I replaced both 02 sensors...again since they were only a few months old. Voila! No more CEL's after hundreds of miles of driving in the last week
ST fuel trims on both banks look great and AFRs are almost identical on both banks (also watching with new PLX gauges) The takeaway here is...swapping the sensors isn't always good enough because when I swapped them the CEL didn't go away. I'm not sure why it didn't change to a p1155 when I swapped them but for now I am going to enjoy the CEL free and misfire free driving! Happy new year!
Old Jan 6, 2014 | 11:51 AM
  #32
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
Some guy on renntech had same issue he replaced everything only to find out it was a cracked header. Check your headers out...
Old Jan 6, 2014 | 12:50 PM
  #33
mrmaass's Avatar
I saw that thread and I checked this out before I did anything a couple months ago after reading the description of what causes this code.
Anyway...the whole point of the last post was that the CEL is gone now so no need to recheck for exhaust leaks.
Old Feb 12, 2014 | 06:14 PM
  #34
mrmaass's Avatar
And it continues...
Since my last post, I got another misfire and the P1145 returned. It turns out the misfire was on cylinder 3, where I moved the injector that was misfiring on cylinder 1. I'm not sure why it took so long to reappear but it did. I got another injector from EPL and that fixed the misfire, hopefully for good.
Logging showed a new boost spike also. It hits 1.5 with the 91 octane tune and 1.7 with the 100 octane tune at fairly early revs. I checked the wastegates and replace the N75 but still no improvement. For now I'm running the 91 tune with 100 fuel to avoid damage.
I finally broke down and took the car to the local shop to perform the "small valve lift" test that is called for. They tested it in the shop and it was fine and the final part of the procedure calls for a WOT pull while a passenger operates the Porsche system tester. The mechanic was freaked out by the acceleration and said it wasn't safe to perform (he has no dyno).
The shop also said they did a smoke test help fix the boost spike and they found no leaks. After picking it up from the shop, it runs perfectly but 5 minutes later, CEL light comes on. This time it's P0171 an P0174...probably a vacuum leak.
If I never see another CEL it will be too soon. I guess I will do my own pressure test again and maybe put some electric tape over the CEL. I just want it to be right again.
Now I have the old P1145 and a new P0171 and P0174 and I'm no closer to resolving anything.
Old Feb 12, 2014 | 07:59 PM
  #35
stock injectors and stock tune... try it...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 12, 2014 | 10:10 PM
  #36
mrmaass's Avatar
I'm not sure if you are being sarcastic or not, but if you're not - this setup was running perfectly for 4 months before any of these problems so I don't think the injectors and tune are the cause, and the stock injectors aren't up to the task of fueling my Alpha 28s at any decent power levels anyway.
I refuse to give up, the problem has a solution; I just need to find it.
Old Feb 12, 2014 | 10:13 PM
  #37
I meant it. That would rule out the tune with injectors and I'm guessing 5bar. Seems like your doing just about everything else.
Old Feb 12, 2014 | 10:21 PM
  #38
mrmaass's Avatar
Once I get the boost spike resolved (I'm sure the shop's tech missed something with his smoke test) and I verify that the AFR's on both banks look good I think I'm going to just ignore the p1145 since it is actually running fantastic at every RPM from idle to WOT.
For the record I've got a stock 3.8 bar FPR and you're right, I have tried just about everything to get rid of the CELs
Old Feb 13, 2014 | 03:06 AM
  #39
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
What mods does your car have? How many miles ago did this start? What changes, if any, did you do in the 5k miles prior to the problem starting?
Old Feb 13, 2014 | 10:16 AM
  #40
mrmaass's Avatar
My mods are in my signature and they occurred ~4K miles prior to these issues starting.
Old Feb 13, 2014 | 11:36 AM
  #41
Originally Posted by sharkster
Well it's an easy thing to do just look at the filters and make sure there's no metal shavings in there just to be sure. You won't really see the slivers in oil you drain....
Good sign that they were clean tho. Reason I bring this up is a car came in with similar codes and sure enough... Those lifters do fail sadly. Wasn't driven enough to trigger more misfires in other cylinders.
We've certainly seen leaky injectors over the years (seimens ones that folks use for 700hp kits). Rare but happens. A 997tt also had one bad injector which caused a nasty issue too but factory ones seem immune. That can lead to misfires too yes.
On the sound if you have a loud enough exhaust it's pretty quiet as far as the sound. But hopefully that isn't an issue anyway.
Have you logged your FRA adaptation long term?
Old Feb 14, 2014 | 03:33 PM
  #42
mrmaass's Avatar
Both banks are identical and couldn't much better at +1%
It is so random...I watch my PLX gauge monitoring two standalone W/B O2 sensors and 90% of the time both banks are extremely close together. Sometimes, they are off by a noticeable margin. This happens when I've been driving it for a while and an example is bank 1 will show an AFR of 13.6 while bank 2 shows 15, or bank 1 will show 13 and bank 2 will show 11.5. This is always under light throttle inputs. As soon as I give it some both banks go right back to being close until I let off the throttle. Restarting the car fixes this and both banks will once again remain close at all throttle inputs.
The gauge really helps to see what is causing the P1145 CEL.
So strange!
Old Feb 14, 2014 | 03:43 PM
  #43
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
Could it be MAF related?
Old Feb 14, 2014 | 03:47 PM
  #44
mrmaass's Avatar
Not likely - MAF is very recent and voltage readings are right on target. That was one of the first things I changed.
Old Feb 14, 2014 | 04:01 PM
  #45
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
I had the exact same code(s) P1145/P1155 this past year, car ran great albeit light low throttle position hesistation, CEL would come on if car was driven a fair bit a lower throttle opening...I have no misfires
New O2's, MAF, plugs coils etc etc...did pressure test at end of year right before storage and found a large leak at wastegate seal, will replace wastegates this winter and see if fixed in Spring..
