installing GT3 seats...
Old Nov 6, 2003 | 01:36 AM
Chris Y.'s Avatar
Chris Y. is infamous around these parts
Hi...
I found this link to installing GT3 seats...It's in a Boxster, but I think it's pretty much the same.
Here's the Link: http://members.aol.com/ericbosco/gt3/page_01.htm
Question: After removing the wiring harness from your original seats, is there anything to reconnect to the GT3 seats???
Does anyone have the torque figures of the screws???
Old Nov 6, 2003 | 05:54 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
What's the link??? I believe the torx key size is 40....
Old Nov 6, 2003 | 06:04 AM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
Some install tips courtesy of Viken...
1- Remove ignition key
2- Type and size of socket: E12 reverse torx
3- Modify the electrical harness plug for proper airbag light function (the only part retained is the square green plug and it must go back the same way)
4- Replace the seatbelt buckle on new seats
Old Nov 6, 2003 | 06:35 AM
ColorChange's Avatar
ColorChange is infamous around these parts
Kind of a stupid quesion but, how do you handle the seat belt light issue if you are going to go with a harness?
Old Nov 6, 2003 | 07:25 AM
Sloth's Avatar
Here is a link to an install that I found.
Old Nov 6, 2003 | 07:27 AM
Sloth's Avatar
I would hook up the seat belt recepticle as normal, then puchase an extra seat belt clip to put into the recepticle to keep the light off when using the harnesses.
Old Nov 6, 2003 | 09:02 AM
rockitman's Avatar
Here's a great GT3 seat install link
Did a forum search...Dohhh!!!
Provided by dan996TT back in July!!!
Hey Sloth, you beat me to that link. Sorry for the redundancy guys.
Old Nov 6, 2003 | 09:34 AM
j993's Avatar
j993 is infamous around these parts
No problem - good luck!
Jeff
Old Nov 6, 2003 | 11:21 AM
Chris Y.'s Avatar
Sorry guys...yeah, my link is the same one the rest of your guys put up.
Doesn't look too hard...i think i'll be able to do it when I get my seats next week.
Old Nov 6, 2003 | 11:29 AM
rockitman's Avatar
Yeah, the seat install looks rather simple. It's nice that the instructions give you a logical road to follow rather than wasting time guessing and experimenting. The roll bar will be another story. I will knock that off once the sports seats are out and prior to putting the GT3 seats in. Should be good use of most of the day...
Old Nov 6, 2003 | 11:34 AM
Chris Y.'s Avatar
The rollbar does looks a bit more complicated. I'm a bit worried after hearing comments like "the alignment of the mounting may be off"...humm, doesn't instill must confidence in this safety device I'm installing.
Old Nov 6, 2003 | 11:42 AM
rockitman's Avatar
Old Nov 6, 2003 | 11:52 AM
oak's Avatar
oak
Sloth and Colorchange, You should be able to eliminate the seat belt light by just pushing in the OBC stalk. It will eventually go off after a few minutes other wise.
Old Nov 7, 2003 | 06:35 AM
Oak:
I was thinking of pulling the front belts completely. Has anyone done this and how do you stop the alarm?
Old Nov 7, 2003 | 09:23 AM
oak's Avatar
oak
ColorChange,
Curious as to why would you want to eliminate the seat belts? I would think if you wanted to eliminate the seat belt alarm and lights, all that would be needed is to close the electrical loop or a a simple jump from the the wires to the belt clip receptical or seat belt.
