Airbag light on
Did you disconnect the battery when you made the swap...(which you must do)? You will need to clear the code (with PIWIS, PST2 or Durametric). If you have installed the GT3 seats properly you will be fine, if not or if the seat belt connector is "damaged" you will have to do further repairs.
Did you wire up the seat belt receptacle to the harness? There's a how-to writeup somewhere.
If you didn't you'll need wire them up properly and use a durametric to reset the light. (I had a light but not code - tried clearing the codes and the light went away)
Plus 1
LiquidElephant
Aug 27, 2015 06:17 PM
GSR Autosport
Aug 26, 2015 05:20 PM
pwdrhound
Aug 23, 2015 07:36 PM
Walorus
Aug 18, 2015 01:39 PM
