Fitting a flex fuel sensor (ethanol sensor)
Old Feb 4, 2014 | 11:29 PM
e8_pack's Avatar
e8_pack is a jewel in the roughe8_pack is a jewel in the roughe8_pack is a jewel in the roughe8_pack is a jewel in the rough
My mapper was unable to fit the flex fuel sensor as the return line was hard piped. Has anyone fitted one, or is there a how-to anywhere with some pics?
It's for the syvecs ECU if that makes any difference.
Old Feb 6, 2014 | 09:12 AM
yeah you have to add some -6 AN fittings into the hardline and put flexfuel there. i just replaced my whole return line with a -8 from the regulator back to the tank.
#TeamAIM
Old Feb 6, 2014 | 10:28 AM
e8_pack's Avatar
Cheers. I've seen some diagrams on auto Atlanta, did you fit it next to the tank or is there a better spot. I see there is also a fitting under the car but probably not the best place for a sensor.
Old Feb 12, 2014 | 09:03 PM
Tim941NYC's Avatar
Do you still have the front drive?
Old Feb 15, 2014 | 11:40 AM
e8_pack's Avatar
Yep.
Old Feb 15, 2014 | 11:43 AM
e8_pack's Avatar
The quick connects to the fuel pump are 5/16, but they are shallow and my 6an coupler won't fit so I need to get a new quick connect from pump and a rubber hose as I have PTFE to my 6an fittings.
Old Feb 17, 2014 | 07:32 AM
depending on how much fuel you are moving the flex fuel sensor is pretty restrictive. on my car i have a -8 return and i split into two -6 before the flex sensor, one goes thru it and one is free flowing, then come back together to a -8.
Looks something like this .... ----<===>----
#TeamAIM
Jul 29, 2019 11:13 AM
tkebp1275
Aug 31, 2015 06:35 PM
The Oss
Aug 24, 2015 08:19 PM
Nissan GTR
Aug 19, 2015 02:11 PM
