SAI Delete questions
Old Feb 10, 2014 | 12:52 PM
mbgt72's Avatar
mbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud of
Just curious if anyone has deleted their secondary air injection system. If you're catless it's pretty much worthless anyways and just taking up space & weight.
I saw these people sell blockoff plates here: http://store.gospecracing.com/boxsteroilseparatorventline-1.aspx
But was curious if anyone has personally done this on their Porsche and know which vacuum lines need to be re-routed & tied together.
I know the car can be coded for RoW vs US and it should prevent a CEL or obdII emission testing codes as with most cars. But was mainly curious about what needs to go where and what needs to be tied off / removed.
Below is a link of a SAI replacement I found via google for a NA 996:
http://p-car.com/996/diy/sai/mainpage.html
and the picture showing the 2000+ SAI diagram:
And another reference of the turbo system:
And finally, a more detail vacuum diagram of the adjoining systems:
ID:	331637   Click image for larger version
ID:	331668   Click image for larger version
ID:	331669   Click image for larger version
ID:	331670   Click image for larger version
TheInfamousDrew
Aug 19, 2015 12:45 PM
